| RRSPORT.CO.UK | ||
|  | Home > General > Rear Diff Fault, Software Updates |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Is it under LandRover std warranty? If so, software fixes should be done. If extended third party then they will cover failure, not preventative (the diff hasn't failed, it's just noisy) if you tell them about it, then they will remove cover as you could have done something about it when you knew it was failing....
|  Thu Oct 04 2012 7:52am |
| ARHRRS Member Since: 14 Jan 2010 Location: Birmingham Posts: 36      | It is an '08 HST.
|  Thu Oct 04 2012 8:10am |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Did it resolve the noise? Sounds like cowpoo to me. Having suffered several diff failures I would be a little bit more persistent in getting it resolved before you get a bill for £1500 plus vat for a new diff. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Thu Oct 04 2012 5:34pm |
| Louiscypher Member Since: 29 Sep 2012 Location: Northampton Posts: 42    | Bodsy, I've a '09 HSE and not sure what updates I have/need? I see you're around Northampton on the 12th and wondered if there's a chance to get something done (if I need it...)? I'm in Hospital from around 11am so it'd need to be early.
|  Fri Oct 05 2012 4:24pm |
|  Fri Oct 05 2012 4:25pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Hi Adrian,
|  Fri Oct 05 2012 4:46pm |
 Damn, I was looking forward to spending some money! '10 RRS 5.0 SC '13 Cayman S | ||
|  Fri Oct 05 2012 4:50pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Well I can help you do that, read your fault codes, fire up your FBH a d check for updates. But nothing specific...
|  Fri Oct 05 2012 4:52pm |
 You're certainly persuasive, I'd be keen to check for the updates, reset the gearbox so it can learn my style as I only purchased the car a couple of weeks ago. '10 RRS 5.0 SC '13 Cayman S | ||
|  Fri Oct 05 2012 4:59pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Drop me a PM with your postcode and a mobile number and I'm sure we can catch up at some point.   | ||
|  Fri Oct 05 2012 5:38pm |
 Done, many thx. '10 RRS 5.0 SC '13 Cayman S | ||
|  Fri Oct 05 2012 5:56pm |
| ARHRRS Member Since: 14 Jan 2010 Location: Birmingham Posts: 36      | I have had the car back now for a few days but the judder/ rumble noise is still there but not as bad, but it is getting more frequent the more I drive it. They cleared multiple fault codes relating to the Rear Diff control, repaired the harness to the Temp Sensor on the diff and carried out Rear Diff Control Module Update.
|  Tue Oct 09 2012 7:46am |
| ARHRRS Member Since: 14 Jan 2010 Location: Birmingham Posts: 36      | I have now had an error message flash up, "Transmission Fault, Reduced Traction"
|  Mon Oct 15 2012 10:28pm |
| Posting Rules
