Home > General > Tow Bar
lee551247
Tow Bar
Will a 2008 Range Rover Sport TDV8 HSE come with a tow bar and electrics? Am i right in thinking i just need to buy the detachable ball?
Thanks
Lee
Post #358557 Tue Oct 02 2012 9:40pm
muddywheels
Milk Float Man
You need detachable towbar and electrics unless previous owner fitted them Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #358559 Tue Oct 02 2012 9:55pm
lee551247
Thanks, I don't think the previous owner has fitted them as it doesn't come with a tow ball, Are the electrics hard to fit or are they plug and play?
Post #358560 Tue Oct 02 2012 10:00pm
muddywheels
Milk Float Man
Just done a search and you may need activation http://www.rrsport.co.uk/forum/topic27033....w+electric Embarassed
Look behind the bumper cover - some owners keep the tow bar to sell or use on next LR but leave the electrics Thumbs Up
TB FS on Disco http://www.disco3.co.uk/forum/topic84219.html Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #358563 Tue Oct 02 2012 10:11pm
You need to check behind the towing cover in the rear bumper. Mine didn't have the tow ball (I guess he kept it for his next one) but the electrics were fitted. Tow balls can be had reasonably cheaply from the usual suspects... 2012 SDV6 - it's missing a couple of cylinders
Post #358575 Tue Oct 02 2012 11:20pm
lee551247
I purchased the electrics from a Land Rover Specialist and they told me they would 100% not work without activation, they wanted to charge £50 + VAT for activation!! So glad i never paid it as low and behold they work perfectly!!
They also wanted £150 to fit them! I fitted them in an hour!....Fairplay some dealers / specialists do try it on! Thumbs Up
Post #358803 Fri Oct 05 2012 9:02am
muddywheels
Milk Float Man
Glad you got sorted Thumbs Up
I initially thought RRS did not need activation but then read the post I sent you so was not sure Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #358805 Fri Oct 05 2012 9:39am
lee551247
Thanks for your help mate Thumbs Up
Post #358822 Fri Oct 05 2012 10:44am
mse
The electrics on a 2008 require more removal than a 2013MY car (the later cars its a connector behind the bumper, earlier cars you have to go further into the car behind the trim)
On my 2011 and 13 cars, whilst you have to activate them for the FEATURES (reversing sensors cancel, tow assist etc), the standard features (lights) work on there own straight away...thats not to say earlier cars are the same. Mike
2014 Facelift Discovery
Post #358887 Sat Oct 06 2012 9:55am
Bodsy
Site Sponsor
Earlier cars will work no problem just by connecting the electrics. If you enable them, then it will stop the car automatically going into off road height if you select the relevant terrain response setting and have something connected. Fo almost all owners it will make no difference to your use. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #358889 Sat Oct 06 2012 10:43am
lee551247
I may have spoke to soon, I have just realised my reversing sensors don't work now! I get a long beep from the rear and the LED on the button just flashes, Could this be that the car needs telling that a tow bar is fitted?
Post #359013 Mon Oct 08 2012 3:51pm
muddywheels
Milk Float Man
The reverse sensors only disable when towing if the software updated - alternative is to manually disable "P" button (rh side next to Hazard warning on mine) when you are hitched and reversing like I used to on the FL1 Sad
Post #359016 Mon Oct 08 2012 4:05pm
lee551247
muddywheels wrote:
The reverse sensors only disable when towing if the software updated - alternative is to manually disable "P" button when you are hitched and reversing like I used to on the FL1 Sad
I might take the boot side trim off and disconnect the tow bar electrics and see if the sensors work again as it might be something in the wiring making the sensors not work Sad
Post #359017 Mon Oct 08 2012 4:13pm
