![]() | Home > Technical > Auto door locks now not unlocking... Make any sense.? |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Might be worth taking the door card off again to make sure you didn't omit to re-connect one of the plugs or maybe one worked loose when you were re-fitting the card. I had my driver's door card off recently to change the lock latch and recall there were a lot of plugs - it's easy to miss one. Alternatively - the motors in the latch are known to be a bit flakey; (one of mine was) they don't stop working altogether - just don't exert enough torque to fully lock or unlock. Moving the door card probably would jiggle the lock mechanism and might have exacerbated the problem if it was developing? Good news is the latch is only about £40
| Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259
Thanks for that
