| RRSPORT.CO.UK | ||
|  | Home > Technical > issue with intermittent heavy steering |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | Personally I'd look for a slipping steering pump belt... but I'm not sure a RRs has one..
|  Wed Oct 03 2012 10:22am |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | its probably just the steering column UJ a bit of spray grease should make it better for a while. Replacement is about £50ISTR + fitting of course. Bodsys Brake Bible
|  Wed Oct 03 2012 1:34pm |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441      | Hello , its definitely not a slipping belt, it feels more electrical as though there is a faulty sensor, and it has not sensed the movement of the steering wheel. And it also does not really feel to be a uj as other can be perfectly ok at times then suddenly play up. I think the sc has speed dependant steering. So could be a sensor? | ||
|  Wed Oct 03 2012 2:45pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Could you repeat that just one more time please Shepp   | ||
|  Wed Oct 03 2012 8:34pm |
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422      | same problem i have | ||
|  Fri Nov 23 2012 7:22pm |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | I assume you've checked the power steering fluid level?
|  Sat Nov 24 2012 11:12am |
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422      | Looked at the fluid today and in was on minim topped up to max now so will see if it drops in the week think its 50% better but only drove 2 miles home after the top up | ||
|  Sun Nov 25 2012 4:18pm |
| Posting Rules
