![]() | Home > Maintenance & Modifications > decat pipe mod |
vic_ster51 Member Since: 21 Sep 2012 Location: east anglia Posts: 28 ![]() ![]() ![]() |
Anyone ever fitted decat pipe to there sport... i have 2005 model was looking at this.... just wondered if easy straight swap over fit etc.... current system is fully standard
m22 gtr Member Since: 18 Apr 2011 Location: edinburgh Posts: 399 ![]() ![]() |
Looks good I would like to try it |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
So how do you tell the engine management system that the cat has gone?
shouldnt fault anything i dont think
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9081 ![]() ![]() ![]() |
Since spring of this year, if the vehicle has a cat fitted as standard (and they all do these days) and it is not present at the test then it's a straight fail.
DMike Member Since: 09 Nov 2007 Location: Perthshire Posts: 79 ![]() ![]() ![]() |
No its not. It only has to be present on a vehicle which is subject to a full CAT test. Currently this is PETROL CARS ONLY. If you have a diesel, you DO NOT need a cat to pass an MOT, as they are only subject to a smoke test To the OP, get it bought and fitted. Will release a few extra HP, will give you a big more low down torque, and the turbo spools up quicker. Definately a noticeable difference, and one of the cheaper mods available ![]() |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Yes however exhaust systems are checked for 'completeness' regardless of engine type. Missing CATs are a fail therefore I presume.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4496 ![]() ![]() ![]() |
I appear to have broken the links. Will update this evening. You DO NOT need a cat for an MOT... |
Taken from here: http://www.306oc.co....hread-2831.html
And this was the reply, directly from VOSA...
And also, copied from the MOT testers manual...
Its is only petrol cars that are subject to a full cat test, diesels are only a smoke test... I hope this clear up any confusion ![]() |
MIke,
Yup, same as aftermarket HID kits...
