Home > Technical > "Special Systems Off" - What's it mean ???
Reidy4862
2005 Range Rover Sport TDV6 Zermatt Silver
Hiya All
Every now and again, specially on Cold Mornings or when My 2005 RRS has been stood I get the Message "Special Systems Off" when I start using the car it's completely fine and everything works, as the the day goes on the message doesn't seem to appear again.
Like I said its seems to be on clod mornings or if I haven't used it for a while.
Please Help
Post #357095 Wed Sep 19 2012 8:39am
muddywheels
Milk Float Man
Normally see this On mine after mud, snow, etc settings turned off and back to normal Thumbs Up
Sorry mine says special program's off Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #357096 Wed Sep 19 2012 8:45am
Bodsy
Site Sponsor
Its because your battery is low on charge. If its the original battery, it could be a sign that it needs replacing sooner rather than waiting until the depths of winter when it takes your alternator out too... Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #357098 Wed Sep 19 2012 9:02am
Reidy4862
Cheers.
So the Battery needs Changing ??? Wondered why the car seems to have to put a bit of effort in turning on first thing of a morning or on Cold Starts. Going on Holiday for a Fortnight in a weeks time and the car will be parked at the Airport, You advise I should change it before I go ????
Post #357099 Wed Sep 19 2012 9:16am
Bodsy
Site Sponsor
Yes, and charge it fully also.
Another point, could be that you have an electrical drain on the car. Usual things to cause that are a failing starter motor (you say it's been struggling) or a failing alternator.
But battery is first port of call. Keep the old one for a while, just in case it is something else that 'may' fry the connected battery. Thumbs Up Bodsys Brake Bible
See it HERE
Post #357101 Wed Sep 19 2012 9:23am
Reidy4862
Well I wouldn't say struggling really just seems to start differently to the rest of the day if you know what I mean, you don't need to have the keey turned long for the car to turn over, just seems like a low battery like you say, for the rest of the day it is fine and the message doesn't appear
Post #357102 Wed Sep 19 2012 9:38am
^^^ Also a battery drain could be the upper tailgate release switch that's become corroded Wink ON THE WAY: BMW F21 M140i
Post #357103 Wed Sep 19 2012 9:39am
Reidy4862
Veers for all ya Help, the Tailgate release seems ok with no signs of Corrosion
Post #357106 Wed Sep 19 2012 10:15am
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i had this come up on mine and when it did it knocked theflashing light for the low tyre pressure warning off ,l
Post #357134 Wed Sep 19 2012 5:43pm
Reidy4862
I have noticed to that when I change from Snow, Mud etc back to Normal that my screen shows "special Program's Off"
Post #357191 Wed Sep 19 2012 11:22pm
