Home > General > Pfft...
Pufftmw
Pfft...
I wandered around my car & found that a pdc sensor was not working. I obtained a new sensor from fleabay. I downloaded the instructions on how to remove the rear bumper. I removed said rear bumper & replaced sensor. PDC still did not work Sad I checked the loom had been properly connected, it hadn't so I connected it ( Embarassed ). PDC still did not work Sad Rather than take off the whole bumper again, I again tested connector then thought I would check the fuse just in case. Removed fuse and it was ok, so went to put it back in again. Dropped fuse and fuse tool down the back of the trim Sad Spent ages trying to recover fuse tool and ripped hands to shreds Sad Eventually got it out (not the fuse though) but what a pita. Only brightside is that with the fuse removed, I don't get the annoying "PDCs not working Razz " noise every time I select reverse.
Going to have to f@rt @rse about again to remove bumper and check all the bloody fittings and sensors Sad
Pfft...
Post #356927 Tue Sep 18 2012 12:27pm
Having a good day then Whistle Laughing
Does sound a bit of a ball ache though Sad ON THE WAY: BMW F21 M140i
Post #356930 Tue Sep 18 2012 12:36pm
