Home > General > Car dead after 1 week holiday
Sirwacko
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
I've been away twice in the last few months for a week. Each time I return home the car is dead. Completely flat won't even open the doors! Sad is it the battery dead or something draining it? Please heeeeeeeeeelp! RRS Dynamic
Post #356771 Mon Sep 17 2012 8:44am
Sheesh....the worst "I've been on a few holidays recently' thread Whistle Laughing
Seriously....it could be something not shutting down thats draining the battery, I'm sure there are posts on here about the boot release mechanism doing a similar thing (easy fix if thats the case) Smile
Failing that, it could be a sign that your alternator is on the way out/dead as you may not be recharging the car when you drive it Idea
Either way, best get the car on charge and to a garage soonish Crying or Very sad ON THE WAY: BMW F21 M140i
Post #356773 Mon Sep 17 2012 9:02am
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
i had this before mate it was my upper tailgate realse button corroded behind the rubber and was causing a permant live think that was about 80 quid to fix. alos do you have a fridge if your leaving that on when away this can affect things or so lr told me , but you might need a new battery now aswell as mine had been affected by it going dead all the time but since got tailgate done and new battery not had a problem and mine often gets left for a few weeks at a time only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #356778 Mon Sep 17 2012 9:26am
If you are in the AA/RAC then call them out, they will put their electronic machine on your battery terminals to see if there is a continuous drain on your battery, then i'm sure they will be able to detect where it is. If your not in any breakdown/recovery service, then may i suggest you join one. Thumbs Up
Post #356792 Mon Sep 17 2012 11:33am
baxc
dont think aa/rac are going to spend hours trying to detect a drain on your battery pulling fuses and shutting down each ecu check your upper tailgate switch this is normally the cause of a battery brain Thumbs Up
Post #356833 Mon Sep 17 2012 5:40pm
Tim in Scotland
The other thing - do you lower it to access mode when you go away? With pre-2010MY cars
lowering them to access height tells the ECU's to go completely to "sleep" instead of stand by mode and shut the car down to save power consumption, although I would expect it to last longer than a week in normal height. I used to leave my RRS's unrun for 4 months at a time and also used to plug a £19.99 Maplin's Solar powered trickle charger into the boot socket and put the panel on the centre cubby box as it only needs daylight rather than sunshine to work. Never had a dead battery on any of my RRS's or FFRR's but this summer I came home to a totally dead Evoque................... with the solar panel plugged in but no indicator LED blinking. Checked it over and found the car hadn't drained the battery the cable for the charger had broken at the joint with the panel and the battery had discharged
because of that. LRE took a Disco4 and a 700v jump starter box thing both connected to the battery terminals to get it back to life. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #356842 Mon Sep 17 2012 6:45pm
Oh yes they do, but it doesn't take them hours, they have some clever kit in their vans, otherwise they will have to keep coming out to you everytime your battery goes flat costing the company more money. They have to diagnose and try to fix the problem where possible. Otherwise they can't fill in their report in the actions taken to solve or repair the problem and it goes against the companies action policy Whistle
Post #356844 Mon Sep 17 2012 7:50pm
baxc
solve problem-battery dead, repair problem-jumpstart dont think they are going to check every system in the car if they have got you going just incase its a battery drain when it could just be a wornout battery i know this because i called the aa out twice for my battery drain, on both occasions they jumpstarted the car and checked output of battery when running and after systems had shut down both were fine because drain was so small it took a week to drain battery with the car not being used the aa/rac dont have that much time to fix a job Whistle
Post #356858 Mon Sep 17 2012 8:47pm
I beg to differ, but will leave it at that.
Post #356860 Mon Sep 17 2012 9:08pm
Cheney Jawa
Picked my new one up yesterday & the dealer mentioned similar to me about if i was going to leave it a long time stood then lower the suspension because if you don't the battery will drain Very Happy Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack
Post #357275 Thu Sep 20 2012 12:36pm
Sirwacko
Cheers for all of your advice guys. It's booked in for tues! RRS Dynamic
Post #357295 Thu Sep 20 2012 1:55pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Just retuned to the car from 12 days away. Parked (at home fortunately) with the suspension lowered. Dead as a DoDo. Charged the battery for a while then started fine. Everything reset (clock, date, A/C, seats).
Can't be right. Car is 6 months old.
Post #358132 Thu Sep 27 2012 10:22pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Exactly my experience with the AA.
Post #358146 Fri Sep 28 2012 6:08am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
it's in their interest to prove/suggest the battery is faulty so that they can flog you a new one there and then. The AA especially heavily incentivise their drivers to make sales like this. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #358375 Mon Oct 01 2012 12:18pm
Sirwacko - did you get this resolved ? what was the problem/fix Question ON THE WAY: BMW F21 M140i
Post #358379 Mon Oct 01 2012 12:41pm
