![]() | Home > Off Roading & Green Laning > Wading depth |
Yes - there are no wing intakes anymore on the new FFRR. The "vent" like trim on the doors is an ornament and of no practical use. Like the Evoque the intakes of the L405 are on top of the front wheel arches, under the edge of the clamshell bonnet, nicely protected from sucking in water or sand. This gives the Evoque the same wading depth as my Defender - 500mm and how the L405 can get 900mm with off road height in use - will be even more if you get the car into extended height!
| flydive Member Since: 17 May 2007 Location: South Posts: 1213
Pre 2010 RRS have a wading depth of 700mm too. '08 RRS TDV8
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138
Not according to the owner's manual they don't... 2012 SDV6 - it's missing a couple of cylinders
There seems to be a bit of confusion on the informations.
Yes, it's odd isn't it?
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
The handbook for my 07 2.7 has wading depth of 540mm. I do not understand why the later models would have a higher wading depth as the intakes systems are basically the same with the exception that the pipe that joins the intake to the airbox is waterproof on the later models.
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
They did used to have a separate off road manual in the UK, ive got one for my discovery - its more an off road guide or techniques thing...certainly all in one now. Mike 2014 Facelift Discovery |
| muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644
Now this is wading |
| crookedm Member Since: 03 Apr 2012 Location: North West Posts: 296 |
Can't polish one hey! |
Back to the original question, looking at the LR3 (Disco 3) workshop manual, I think the wading depth is determined by the height of the breather pipes for the gearbox and the differentials.
| mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285
Exactly, this is why breather pipes are fitted.
What about the air intake ? Max wading depth (unless fitted with a snorkel) will be as high as the lowest air intake, breather or engine. You could theoretically wade deeper than the air intake if you can maintain a bow wave and water depression by the air intake, but if you have to stop for any reason, best stop the engine immediately and not restart it
"Roads ? Where we're going there are no roads." Back to the future. |
The air intake is the wing vent and that is much higher than 700mm above the ground in off-road suspension mode. I would expect the air supply path to be air tight (and thus water tight to a reasonable degree). This leaves breathers and electrics as the controlling issue.
Another thing to bear in mind is flotation
True enough but the thing that set me off on this question was what had changed between years in the RRS that meant an increase of 160mm in the published wading depth - floating risk isn't it I'm sure.
