| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Brembo Disks |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | This will tell you how to do most things,
|  Sun Sep 09 2012 3:38pm |
| firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461      | Easy jobby to do and cheap enough, but simply ask them why, it can be obvious from visually inspecting them if they are worn, you will see grooves or usually you can see the original size around the edge if that makes sence. If you took some fog and put it in a jar, would it be missed. | ||
|  Sun Sep 09 2012 6:34pm |
| funnyguy1 Member Since: 18 Jun 2009 Location: Sun Valley Idaho Posts: 171      | You didn't mention year of your car and miles. My 09 has 29k miles on it and I had new front discs and pads installed 5 months ago. The fronts wear faster than the rears. Today I had my rear discs resurfaced and new pads and sensor installed at $266 US.
|  Tue Sep 11 2012 1:09am |
| Bobby_1959 Member Since: 09 Sep 2012 Location: Derby Posts: 2  | Is there a disk thickness or amount of wear which indicates when to change/ | ||
|  Wed Sep 19 2012 6:29am |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Onthe normal and petrol d3 v8 disks, it is 20mm for new and 17mm replacement needed on the rears and 30mm for new and 27mm replacement needed on the fronts.   | ||
|  Wed Sep 19 2012 7:00am |
| Posting Rules
