Home > General > Emergency park brake application
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Has anyone ever tried the emergency park brake application ? If I remember correctly, pulling the parkbrake lever at speed will perform and automatic emergency stop.
I'm sort of curious to try it, yet don't really want to Confused
Would be useful to know how well it really works in an emergency, rather than pondering over it at the time I guess Whistle
Any experiences ?
"Roads ? Where we're going there are no roads." Back to the future.
Post #355785 Thu Sep 06 2012 7:44pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
do it, it's amazing. They do it on the LR Experience days.
it even flashes the brake lights during the stop. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #355790 Thu Sep 06 2012 8:27pm
Danny Byrne
Scotland 2005 Range Rover Sport TDV6 HSE Zambezi Silver
I wish I hadn't read this... I want to try it!!!!!
Post #355791 Thu Sep 06 2012 8:31pm
Gerico
They did this on my LR expierience day - very impressive, we were doing about 70 with the demo guy driving and he told me to pull the handbrake as if he had frozen/heart attack or whatever. It all stopped pretty quickly. I don't think he had to do much correction to the steering etc. but in a real situation I think I'd have been able to do it anyway.
He kept his foot on the gas by the way but all the electronics kicked in, abs activating as well.
Find a quiet spot and give it a go. What could possibly go wrong Shocked
I haven't actually tried it in my car Very Happy
Hope that helps Thumbs Up
Richard
Post #355792 Thu Sep 06 2012 8:31pm
mrfrog
You guys try it and report back, then I might !
Trying at 70mph though Shocked Shocked Shocked Maybe make sure nothing's loose in the car and that your seatbelt is nice and tight Wink
Post #355808 Thu Sep 06 2012 9:24pm
Bodsy
Site Sponsor
ive done it at 60mph to test it, just applies the normal brakes (sharply!) but brings it to a stop all under control, its a bit wierd, but works very well. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #355816 Thu Sep 06 2012 10:45pm
I've done it. It's impressive in the way it works. Basically it just chucks the anchors out and uses the ABS to control it all - it's an emergency stop just as if you had buried the brake pedal. And it does it even if you have your foot on the throttle pedal.
Go on, play. You might learn something. Just do it on a straight bit of road with little, if any, camber and make sure there's no one behind you.
You need to hold the switch up for 3 seconds (I think) before it activates the system. 2012 SDV6 - it's missing a couple of cylinders
Post #355829 Fri Sep 07 2012 12:45am
garrycol
Australia
Not sure of the logic of the emergency brake in an emergency - even though you actually pull the handbrake lever it activates the main brakes - now the only real reason you would want to use the emergency brake in an emergency is if the main brakes have failed so how does the emergency brake work in these circumstances???
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #355833 Fri Sep 07 2012 3:33am
mrfrog
That's a pretty long time to wait in an emergency !
Garry
I guess it takes all the guesswork out of the equation, pull lever and hold on, it will brake the car in the most efficient way possible (caveat above 3 seconds delay). Sure, planting your foot on the brake pedal is technically easy, but when ABS kicks in, how many people wonder what is going on and potentially lift from the brake pedal ? I also saw it first in a Passat we hired years ago, so not just a LR thing.
Post #355846 Fri Sep 07 2012 9:10am
rrsboy
accelerated stop. I've never used it in anger but can perfectly imagine reflex pull on the handbrake from speed, say, on the motorway Thumbs Up
if I remember correctly the ABS system is utilised to bring the car to a stop as quickly as possible - Bobby has the details! Thumbs Up ============
Post #355849 Fri Sep 07 2012 9:13am
garrycol
Australia
But if the main brakes have failed how is the emergency brake going to work. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #355850 Fri Sep 07 2012 9:13am
rrsboy
I'm not sure it's designed as a "when the main brakes fail" type thing. But (I'm sure Bobby can explain better) the mechanism can likely also use the traditional handbrake. ============
Post #355853 Fri Sep 07 2012 9:18am
rrsboy
here we go:
If you pull the parking brake lever at any speed above 6 mph, the EPB module will electronically request the ABS module to apply brakes to all four wheels. When the car comes to a complete standstill, the hydraulic pressure from the ABS module is released and the parking brake engages normally on the rear drums. It's called "Dynamic Braking".
The system is very sophisticated: During dynamic braking for example, the EPB module also monitors the deceleration ratio through the wheel speed sensors, and if for any reason (because of a defective ABS module, complete hydraulic failure or faulty CAN bus communication between the two modules, all of which would cause ABS not to operate as requested) it detects that the car is not slowing down at a specific rate, it automatically engages the parking brake shoes instead, so you will still come to a stop eventually, just not as quickly. If the ABS module works but is unable to apply brakes - e.g. because of hydraulic failure - the EPB will actually "use" the ABS module and sensors to apply the parking brake with anti-lock on the rear wheels, and still turn on the rear brake lights in the process!
Pretty amazing. ============
Post #355855 Fri Sep 07 2012 9:20am
