![]() | Home > Maintenance & Modifications > problems, regarding RRS brakes and handbrake |
| marco247 Member Since: 25 Apr 2012 Location: Hull Posts: 57
The LR font of all knowledge says that the back brakes have to be backed off by 5 clicks to give the correct slack in the cable.Which is what the garages dooooo becuase thats what it says so must be right!.But when you speak to a seasoned LR mechanic ( not a YTS trainee that most use) they reckon its around 10 clicks (not in the book) otherwise |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324
Had the same issue. Hand brake module. This has happened to a few RRs owners. |
| B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450
what? a problem with it, and needed to be replaced ? |
yep, though it only happened once with me but i ve heard some people had to replace it. £350. Scary when it happens is nt it? i was doing 70, the rear end shook etc. Melted my hand brake shoes and the hubs were cooking!! |
mine wasn't that bad, slight vibrations, a little slowing down, felt a bit like a puncture, but just half down, not flat - then the smell ! Hoping its adjustment after pads/discs fitted as marco247 stated |
| shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948
am i missing something here ?, i replaced my rear pads about 6 weeks ago, saved and reused the silly warning brake lead, and didnt do anything else, and all has been great, i also replaced the front pads a little over 3 weeks ago, the discs will need changing next time though 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
maybe, mine were done 8 weeks ago. the AA man says modules can take a bit of time 'catching up' ! |
So how do i check it ? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
do 90mph down the M4/5/6 . Lol |
Just done that on the M61 on the way home, its not the same as the M6 though, will that be ok ? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
it should be backed off 8 clicks or 1 complete revolution of the knurled adjuster.
i followed that advice when i changed the pads, you only need to back off the adjusters if changing the disc and or parking break shoes, as i did neither, just changed the pads, im ok |
When your changing the pads (so have the wheels off) you should always tighten up and then adjust the epb shoes. If it goes out of adjustment and starts screaming, you have every possibility to knacker it. Bodsys Brake Bible
i understand what you are saying, but as you never go anywhere near the EPB, if your only changing the pads, then why adjust them |
| All times are GMT |
