Home > General > 2012 sport accelerator issues, anyone help?
alfidog
Wales 2012 Range Rover Sport SDV6 HSE Bonatti Grey
New member, first post.
I traded in a 3.6 tdv8 sport in October for the new 8 speed sdv6 2012. I had an issue with it hunting for gears from the start, was advised by sale man to drive it harder. At one point with less than 1000 miles on the car, on a steep s bend hill it couldn't find a gear and virtually rolled backwards. I phoned up, drive it harder, was the answer.
Come to the beginning of July, tried to overtake a tractor at 20 miles an hour up a hill , pulled out , no power (also no fault showing on dash), the car behind me closed the gap and I couldn't get back into my lane!. It happened a dozen or so times on that journey. Called Land Rover assistannce and it was showing a fault when he connected it to his computer PU121-86 (it could be PO, can't read his writing). It also happened with him sitting next to me. He said as I press the accelerator the engine is going to idle.
Land Rover replaced the accelerator (it has two sensors to detect what power you need, one is supposed to act as a backup, in case the other fails).
Yesterday the problem is back, I had my kids in the car, went to pull out of a junction, and no power! It happened several times on the journey home, pretty scary stuff. It has done 5000 miles now.
Anyone had or heard of anything similar? I'm thinking of asking for my money back now, it is too risky to take on a journey. Long suffering Land Rover owner
Post #355255 Sat Sep 01 2012 10:00am
muddywheels
Milk Float Man
I have had this problem on my10 and a sdv6 loaner Sad
Had software update, 2 brake switch and calibration before finally seems sorted Confused
I have discovered fault can be caused by brushing brake pedal while pressing accelerater so need to be more careful when moving foot from brake to accelerater Thumbs Up
Hope this helps Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #355274 Sat Sep 01 2012 1:13pm
Few of us have had this in the early days of MY12 ownership, I've put it down to the system learning the driving 'style' as mines not done it in the last 6 months.
Yours does seem a little extreme though Shocked , I'd be inclined to find a dealer that has a little more interest in resolving your issue though. Thumbs Up ON THE WAY: BMW F21 M140i
Post #355294 Sat Sep 01 2012 7:33pm
mse
Suggestion, if it's hunting for a gear override it and hit the accelerater? Mike
2014 Facelift Discovery
Post #355297 Sat Sep 01 2012 7:57pm
alfidog
At nearly £60k with extras, and my third sport, and my fifth Land Rover product I'm a little tired of giving them the benefit of the doubt!
First 2.7 sport needed new bushes on a regular basis.
Second 3.6 V8 sport needed a new turbo at 25k miles.
This 2012 sport is dangerous.
My Discovery TD5 blew a turbo under a 1000 miles.
My freelander 57 plate was faultless though! Just a little slow! Long suffering Land Rover owner
Post #355306 Sat Sep 01 2012 9:29pm
mse
My 2013my doesn't do this...so it could be just a one off?
Im not sure how much you know about the setup. The car actively learns your driving style and can learn your normal driving, making it slower to do something new...that isn't to say there isn't a fault...but if it was me I would do what I suggested...it has paddles for a reason, click down then put your foot down, it will override auto and force it to do what you want...it will also start to learn that style if you do it enough.
Also have you tried putting into sport first before the manoeuvre? Mike
Post #355310 Sat Sep 01 2012 11:12pm
Bobby
A bulletin was issued last year concerning "Vehicle Hesitation When Accelerating From Low Speed" that affected diesel vehicles from VIN AA215623 onwards. Apparently customers complained of "Reduced engine performance with throttle demand at low vehicle speeds".
The cause was the stop lamp switch was incorrectly adjusted and/or the brake booster had free play. Dealers were advised to:
1. Carry out brake pedal position switch adjustment;
2. Check for brake booster free play and tighten if required.
Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #355318 Sun Sep 02 2012 3:31am
alfidog
Thanks for the replies boys, very helpful.
The fact that it produces a fault code on the diagnostic software proves it sees a fault, and one would think Land Rover would know how to deal with this! Long suffering Land Rover owner
Post #355329 Sun Sep 02 2012 9:57am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
strikes me as more of a fault rather than the 'learning' thingy (which is essentially the gearbox), given how severe it is Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #355330 Sun Sep 02 2012 10:06am
Bobby
DTC P0121-86
Throttle/Pedal Position Sensor A Circuit Range/Performance - Signal invalid
Cause:
• Accelerator pedal position sensor sensing circuit signal invalid
• Accelerator pedal position sensor failure Malaysia Boleh!
Post #355339 Sun Sep 02 2012 10:44am
mse
I wouldn't disagree...but if the sensors were replaced it's a quick way to see...plus it will override any learning issues Mike
Post #355343 Sun Sep 02 2012 10:57am
alfidog
Thanks Boys, the Land Rover technician came today. It was showing the same fault, so he changed the pedal with his Discovery one (two weeks old) and it seems to have worked. It did do it once, but not as severe, and the software couldn't pick it up.
I took it for another drive and got it to do it once going up a hill, to the point that it was rolling backwards, but only the one time. Yesterday it did it a dozen times or more.
I will drive it all week and see how it goes. The only worry is that it can leave you in a very dangerous position on the road! Long suffering Land Rover owner
Post #355363 Sun Sep 02 2012 3:14pm
SVR575
sounds like its still shagged to me! SVR 2018 in Santorini Black.
Post #355380 Sun Sep 02 2012 7:07pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Sounds as if you have a "Friday afternoon build" car?
Take it back to the dealers and demand that they fix the bloody thing!
Jim
Post #355393 Sun Sep 02 2012 9:09pm
alfidog
Ok, it did it about ten times today, got my good lady to video it.
It will have to go back for the third time ! Long suffering Land Rover owner
Post #355441 Mon Sep 03 2012 7:13pm
