Home > General > Front door / body seals part number anyone.
SRE
Spain
Does anyone happen to know the part number of the front door / body seals?
My car an 08 Sport has only done 50,000 kilometres / 30000 moles, however I recently noticed that the front doors had lost their clunk, they are now sounding a tad tiny when you slam them. A closer inspection shows that the front door seals, the seal that is part rubber and part cloth effect mounted on the body has perished / split. Apparently this is not covered by Land Rover extended warranty as it’s down to wear and tear. So I need to source some new ones as cheap as possible Big Cry In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #354647 Sat Aug 25 2012 4:38pm
Misery
Sorry don't know the part number. Think they are about 25 pounds tho.
Post #354656 Sat Aug 25 2012 7:23pm
scrumps
According to my Microcat:-
Seal - Secondary - on body (to VIN 5A910215) = CFE500290
Seal - Secondary - on body (to VIN 8A133346) = CFE500780
The same seal appears to fit all four doors (i.e. front & rear and "not handed").
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - ๐Ÿ˜€
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #354676 Sat Aug 25 2012 9:38pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
get it into LR u might get that done under goodwill if its due to ware
Post #354678 Sat Aug 25 2012 9:53pm
