![]() | Home > Technical > Rear upper tail gate release |
ducati_andy Member Since: 10 Aug 2012 Location: leics Posts: 12 ![]() ![]() ![]() |
Forgot to add that the key fob 3rd button will open the tail glass so there must be power to the solenoid |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Hi Andy Just going to be really stupid here so apologies if you have already tried this or it doesn't apply. I replaced the dead switch in my RRS for the tailgate and at first it still refused to work, so I was a bit p'd off. However, I subsequently worked out that I hadn't unlocked the car twice & when I did, it worked fine ![]() ![]() My unlock button on the remote does the driver door only on first click and then the other doors & allows both the tailgate locks to work on the second click. My 3rd button also does the main tailgate but does not activate the tail glass. |
Thanks pufftmw but had already noted that and found that one remote was programmed for the full tailgate and one for the tail glass on the 3rd button.
stevietee10 Member Since: 07 Jul 2010 Location: Nuneaton Posts: 10 ![]() ![]() ![]() |
Hi
