![]() | Home > General > BUYING A RRS |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
Welcome to the forum. There are a few buying advice threads here. Found the one below by searching for: |
| jakesg Member Since: 21 Aug 2012 Location: hertfordshire Posts: 2
| kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307
On top of the list supplied above, I'd also recommend checking the service history to see if the air suspension pump has been changed. They seem to be a fairly common problem so if someone has changed it for you then they could save you a bit of bob. Also raise/lower the suspension and make sure the car sits level when you return to standard height.
| Reidy4862 Member Since: 29 Feb 2012 Location: Middlesbrough Posts: 48
If there is any outstanding Recalls due on the car then is it still FREE to get the recalls done if you don't have RR warranty anymore ????? |
Yes. My car is a 2006 with 130,000 miles...well past the warranty and they did it for free...changed the brake servo and the vacuum pipes. |
Thanks, I will contact the dealer |
| All times are GMT |
