![]() | Home > General > Aluminium edge for Range Rover Sport Steps. |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
Someone said a while back that the replacement strips didnt fit very well
Franko Member Since: 21 Aug 2012 Location: Glasgow Posts: 13 ![]() ![]() ![]() |
Ok thanks for that.
take it was the pass side? |
yes it was. how did you guess? Range Rover Sport Supercharged 2006 plate |
V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338 ![]() ![]() |
Same happened to me a few weeks back. I brought one from eBay... It's not one that said may need modification, this fitted like a glove. It's a fiddily job tbh but definitely worth doing to avoid spending money on steps! |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 ![]() ![]() ![]() |
I got mine off if eBay and they fit perfect |
Hi guys
http://www.ebay.co.uk/itm/Range-Rover-Spor...2063wt_689
Danny Byrne Member Since: 26 Feb 2012 Location: Dunfermline Posts: 127 ![]() ![]() ![]() |
Rivets along the flat part of the trim. But cut down 2 dumpy self tapers so there short enough not to foul the outside of the trim, fire them in front and back (where they bend round). That's what I done.
Ken
1 G clamp then drill and rivet, then move the clamp round and repeat until fitted. 2.7 TDV6
Big Mike Member Since: 21 Nov 2014 Location: Cheshire Posts: 1 ![]() ![]() ![]() |
Easy guys
The rivets desolve after contact with road salt. I replaced my nearside trim with ones off eBay 2x TDV6. SE and HSE. Both returned to sender with issues👀
Just a suggestion but use stainless steel pop-rivets should last longer.
