Home > Technical > Brembo brakes
farazk
England 2005 Range Rover Sport TDV6 HSE Java Black
Brembo brakes
My car has brembo brakes on it, however I'm not sure if these were on car from new. It needs new pads can anyone reccomend the best place to purchase brembo pads and do I have to use brembo pads for it or can I use other types of pads?
Thanks 2018 SVR
Post #353974 Fri Aug 17 2012 3:00am
fkarim
I don't know if you CAN use non-Brembo pads with Brembo calipers but IMO you shouldn't. No point in having Brembo brakes but using pads that aren't upto the mark.
Try site sponsor duckworthparts. I recently got genuine rear (non-Brembo) pads from Dan at Duckworths at a good price. Turned up the next day and free delivery too Thumbs Up eBay is another option, especially if you want to go non-OEM but I have seen genuine Brembo front pads there too. Can also try nextdaybrakes.com. EBC, Mintex and Ferodo are some brand names with good reputation on the forum in general. What I got in the Land Rover box were pads stamped Ferodo.
You might also need new pad wear sensors as apparently they become brittle with use and often snap when removing.
Post #353975 Fri Aug 17 2012 3:38am
farazk
Thanks for the reply I will have a look at the site sponsor, I have also been looking on eBay and found a few brembo pads, what's the part number I will need?
Thanks 2018 SVR
Post #353976 Fri Aug 17 2012 3:51am
bigphil99
2006 Range Rover Sport TDV6 HSE Sumatra Black
I just fitted ferodo pads to the front of mine in brembo calipers. I could get them at the local motor factors, about £55. If they didn't fit it was much easier to exchange them. Thankfully they did fit and seem to be as good as (if not better) than the brembo. I still have the box somewhere if you want a part number. With regards the sensor there are two or three different types depending on the chassis number of your range rover so make sure and check first. It is a relatively easy job to do yourself.
Post #353984 Fri Aug 17 2012 6:34am
Kensta
eBay, I've got the green stuff pads on mine and got them off the bay Java black 2006
Post #353986 Fri Aug 17 2012 6:37am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Land Rover genuine http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR..._500wt_689
Post #353992 Fri Aug 17 2012 8:33am
farazk
Thanks for the advice mate, if you could get the part number for me that would be really helpful, are there different kinds of sensors for the brembo set up compared to the standard set up? 2018 SVR
Post #354036 Fri Aug 17 2012 12:20pm
farazk
Have you got a link for it? Did you use them in brembo callipers?
Thanks 2018 SVR
Post #354038 Fri Aug 17 2012 12:21pm
farazk
Nice find mate Thumbs Up Do you know how much they are direct from the dealer? £85 seems a bit steep for someone re selling them. 2018 SVR
Post #354039 Fri Aug 17 2012 12:23pm
Martin
Site Administrator & Owner
Best dealer price seems £94+VAT Like this site? Buy some RRSPORT goodies to show your support!
Post #354043 Fri Aug 17 2012 1:06pm
farazk
£112.80 is a lot less than I was expecting from landrover however I may go down the ferodo route like bigphil. 2018 SVR
Post #354046 Fri Aug 17 2012 1:16pm
fkarim
Dan (Duckworth) quoted me a forum price of 87.64 + VAT for front Brembo pads so even cheaper. I checked and mine had a good few thousand miles left on them so didn't buy. However, Ferodo should be fine especially as they seem to supply to Land Rover as well.
Will PM you regarding front sensor.
Post #354049 Fri Aug 17 2012 1:42pm
leedsunited
They are dealer cost, you have PM
Post #354051 Fri Aug 17 2012 1:58pm
bigphil99
Ferodo front pads are FDB1996. The brake sensor I got from dan @ duckworths didn't have enough length on it at the tip to route correctly. It was slightly different from the one I took off. A little digging on e bay and I found two different brembo sensors depending on chassis no. Have a look on there and you will see the different sensors with part numbers.
Good luck
Post #354064 Fri Aug 17 2012 3:16pm
farazk
Good luck
Thanks mate Thumbs Up 2018 SVR
Post #354069 Fri Aug 17 2012 4:16pm
