Home > Maintenance & Modifications > Wheel spacers?
Kensta
Wheel spacers?
Question Anybody fitted wheels spacers to they're RRS? Been told by LR today I need 5mm spacers fitted to front wheels as the brembo Calipers are too close to my inner wheels(they are very close I'm talkin 1mm), my question is has any body else done this and should I fit them to the rear also to not cock the alignment and 4wd system up? Java black 2006
Post #353847 Wed Aug 15 2012 8:55pm
Pierce.M
I've had spacers on my RRS before (7mm) because my aftermarket wheels were too close to the brembos.
Few things:-
If you are particular about your cars (which you probably are) you will need to put spacers on the back too because although 5mm doesn't sound alot, you will notice the front wheels jutting out of the arches compared with the backs.
Because of the above you must get some mud flaps fitted asap! again 5mm doesn't sound alot but I got loads of stone chips up my doors with the wheels now being slightly outside of the arches.
You wont need extended wheel nuts the originals will fit fine.
Out of interest what wheels are you fitting?
Post #353849 Wed Aug 15 2012 9:12pm
Kensta
Hey Pierce thanx m8 Thumbs Up
I have the overfinch supersport replicas on in 22", not sure I cud fit mudflaps to mine as it has the overfinch supersport Sideskirts fitted and I don't thnk the mudflaps wud fit on to them, il look into it tho, wot wheels did u hav on?
Wot made u get 7mm spacers and not 5mm? Java black 2006
Post #353851 Wed Aug 15 2012 9:56pm
I ran 3mm spacers on my D3 with no issues Thumbs Up RRS gone
Post #353908 Thu Aug 16 2012 3:45pm
drdelrrs
What size rims are you running with the Brembos?
If the tight clearance is with the harmonic weights fitted to top and bottom on the back of the front calipers these can be rotated 180 to give more clearance. I have done this on my Sport when the 18inch 'winter' wheels are fitted.
Post #353931 Thu Aug 16 2012 7:35pm
Kensta
Cheers AWD Thumbs Up
DRDLRRS mine r 22" and its the actual body of the caliper that is close to the wheel but thanx tho Thumbs Up Java black 2006
Post #353987 Fri Aug 17 2012 7:41am
