![]() | Home > Maintenance & Modifications > Overheating range rover sport, advice please |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
Don't forget your not supposed to mix different types coolants (so I read once) |
| farazk Member Since: 04 May 2012 Location: London Posts: 41
Tried finding the recomended coolant stated in the manual, however I couldn't find it so I'm going to purchase the premium one from Halfords. 2018 SVR |
| CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59
BE absolutely sure that is OAT type before pour it in the car |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
If you can see water coming out of the edge of the radiator there must be a hole in the radiator. Cause of the hole could be internal corrosion, flying stone damage or another example of legendary LR quality control failure. Topping up the lost coolant might get you home but will not fix the problem. You need to urgently have the radiator replaced or professionally re-cored. If you just leave it to get worse you risk losing all the coolant, severely overheating the engine which will lead to seizure and catastrophic damage. This can happen very quickly on a motorway and by the time you notice there is a problem it might be too late. 2008 MY Java Black TDV8 HSE
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
I think a 2005 range rover on an original radiator is due a failure. Anyway - leaks could also be pipes, connectors that have been working loose and under heat expand and leak On coolant - you shouldnt mix the anti-freeze/coolant solution - but you can buy a special type that can be mixed with existing coolant. The colour is a giveaway - first aim for the correct colour - dont then just put any in its as bad as just water but not as much as not putting any in. Go to the dealer or a real motor factors (not halfrauds) to buy it - it can be bought! Mike 2014 Facelift Discovery |
| All times are GMT |
