Home > General > "Engine System Fault"
Page 3 of 4 <1234>
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
valid point, but just from a risk/reward perspective and with the option for a free exit, I think I know what I'd do.
Tricky call.
Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #352350 Mon Jul 30 2012 7:52pm
mikey7985
Wales 2009 Range Rover Sport TDV8 HST Stornoway Grey
Thanks RRS I think I will cry myself to sleep tonight and go put a deposit on a newer one tomorrow to cheer me up....... Big Cry Thumbs Up 2009 3.6 TDV8 HST
Post #352352 Mon Jul 30 2012 7:55pm
mikey7985
Ok, Just had a call off the "SPECIALIST" who said that the have concluded that there is a Turbo issue with the RRS. They have said that they want to put some Seafoam through the system to see if that rectifies my problem.
Does this sound worthwhile??????? I am dubious!!!!! Crying or Very sad Crying or Very sad 2009 3.6 TDV8 HST
Post #352474 Tue Jul 31 2012 5:07pm
mikey7985
The silence is deafening!!!!!!! I take it no one has any Seafoam esperience???? Rolling Eyes 2009 3.6 TDV8 HST
Post #352484 Tue Jul 31 2012 7:07pm
Nope, sorry Confused Personally, i would just book it in at a trusted dealer and ask them to ring me when they have found the fault instead of everyone guessing. Thumbs Up
Post #352487 Tue Jul 31 2012 7:15pm
mikey7985
I think he is reluctant to send to a main dealer due to high rates so I think I may have to just get my cash back!! Big Cry 2009 3.6 TDV8 HST
Post #352498 Tue Jul 31 2012 8:20pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Ive Seafoamed the oil, fuel system and engine and I can definitely say it is worth it. The benefits are; more power in the low range or better said, restored power. The fuel efficiency also improved. Not by much but it was noticeable. Lastly there is the satisfaction of knowing that there is less Carbon buildup in the system. I can't vouch for any other engine than the 5.0 supercharged petrol.
It was all much easier than I thought. If anyone wants I can do a video the next time I seafoam the induction system.
When used properly Seafoam is a great way to clean your engine and fuel system.
Post #496804 Mon May 23 2016 3:08am
Socast
Seafoam sounds great, but all the crap it flushes from the engine has to pass the lambada sensors and also through the cats...
Post #496808 Mon May 23 2016 9:51am
CANROVER
So they go through the cats. I don't know how they work but I have NEVER had a catalytic converter clog or go bad. Has anyone? I've read this argument before and yes it makes sense but how big are these particles and does a catalytic converter filter it or just let it go through? Can anyone accurately answer that?... WAIT, I'll Google it lol
Post #496839 Mon May 23 2016 5:20pm
CANROVER
Ok I just googled it and basically the way a catalytic converter works is by heating up the elements inside so much that it burns off EVERYTHING and what comes out is just water, carbon dioxide and Nitrogen. Yes it looks like a filter but I will bet that any small chunks of carbon will just get burnt off and dissipate as a gas. The temps in there are in excess of 700 degrees Celsius (From what I saw/read) so that should be enough to change things around as it is intended to do.
I would say that Seafoaming a car that has not had the treatment done in 100,000 miles is probably not a great idea but using a fuel cleaner 4 or 5 times in a row PRIOR to Seafoaming the induction system is better. Again, MY opinion but it only seems logical to me to get rid of the easy to remove carbon build up in small steps before doing a Seafoam treatment.
Post #496842 Mon May 23 2016 6:13pm
TheWojtek
Seafoaming is 'Italian tuneup' for people who do not have any opportunity to drive their car floored for 2 hours straight. Yes, it may remove some carbon buildup. In an engine that holds the oil inside the block because it is sealed with these deposits this will lead to excess oil usage and, eventually, to a catastrophical failure.
Seafoaming is OK if the engine is treated every 25-30k miles from new. I wouldn't recommend it for first use in a +100k miles engine. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #496855 Mon May 23 2016 8:53pm
Socast
CANROVER wrote:
Ok I just googled it and basically the way it works is by heating up so much that it burns off EVERYTHING and what comes out is just water, carbon dioxide and Nitrogen. Yes it looks like a filter but I will bet that any small chunks of carbon will just get burnt off and dissipate as a gas. The temps in there are in excess of 700 degrees Celsius (From what I saw/read) so that should be enough to change things around as it is intended to do.
I've not looked at how seafoam works, but I'll take your word that it raises engine temps etc. Surely though this's is worse than leaving any carbon deposits in situe ? I mean if the temps are that high they could make the carbon burn and pit the surface it is adheared to, not only that but as these lumps fall off they've got to go some where, so could end up trapped in piston rings and scour your liners. A well timed piece could get trapped between the valve and head, stick and then prevent the valve from closing properly until it is cleaned and rebedded.. the list goes on. I'll stick with a can of BG44 every couple of months or so.
Post #496869 Mon May 23 2016 11:22pm
He's referring to catalytic converters when he mentions high temps and burning stuff.
As for this Seafoam stuff, it sounds a lot like RedEx to me.
Simplest thing is to just buy decent quality fuel. Adding stuff to the tank etc is mostly snake oil. 2012 SDV6 - it's missing a couple of cylinders
Post #496880 Tue May 24 2016 8:31am
CANROVER
I agree a lot of the stuff IS snake oil but let me rebut by showing you this video.
I'll also note that the treatment in the vid is NOT on a Range Rover or an 8 cylinder engine but it does testify to the power of the product. This for me was the deal maker and what prompted me to do the treatment.
Now then, I tried this method and it there was not sufficient product to treat the 8 cylinder engine. So I sprayed the contents into a small cup and used the vac line and suction method instead and it yielded far better results. My recommendation is to get the full bottle instead of a spray can to do a Range Rover 8 Cylinder.
Post #496913 Tue May 24 2016 3:03pm
CANROVER
Socast,
I just edited my post to reflect that it does NOT raise the temps of your engine. I'm talking about the temps INSIDE the catalytic converter. Those temps can exceed 700 degrees Celcius.
Post #496914 Tue May 24 2016 3:06pm
Page 3 of 4 <1234>
