![]() | Home > Maintenance & Modifications > Egr valves, blank or remove?? |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Both methods deliver the same results.
| Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170
Thanks for that, budgets a bit tight after forking out for a new park brake mechanism so I'll fit the blanking plates myself. I've read that I don't need gasket sealer, would you agree?? |
When I was going to do mine (on my old D3) The kit just had 2 oval stainless steel tabs that block the EGR pipes... that was it, no aditional gaskets. |
| mikey7985 Member Since: 08 Jul 2012 Location: Bangor Posts: 111
I thought when you blanked these it meant removing them completely anyway??????? 2009 3.6 TDV8 HST |
No Mikey,
Thanks AWD,
Hmm does not look like it... the instructions show this kit removes the pipework but not the actual EGRs. RRS gone
Think I best throw it at the specialist and let them do it!!!! |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442
Had the car faults read today, and one of the egr valves was on the fault list, so thought it may be best to blank them off (2006 2.7).
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
The "suicide pause" is usually caused by the gearbox defaulting to second gear to pull away. Put it in CS 1st as you pull up and you'll find it pulls away much more sharply. 2012 SDV6 - it's missing a couple of cylinders
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Blank and leave the pipe work in place, then at MOT time everything will look normal.
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
Remapping does not fix the pause - it is a gearbox programming issue. 07MY RRS TDV6
The remap has helped, and the Pause is a lot less noticeable. My drive to work this morning was quite pleasurable as she skipped through the gears!
I've used one of the cheap sets, simply two blanking plates, worked a treat. Fitted myself following the instructions with the kit, the only problem I had was the rounding off of two of the bolts, very soft metal, used an irwin socket to remove successfully. No need to remove anything and under the hood looks untouched. I believe the more expensive kits allow you to remove pipework etc, but I didn't feel the need to do that, as I believe it in no way improves performance. Personal choice? |
