Home > Technical > Winch Operation Without Replacing Spare
muddywheels
Milk Float Man
Not sure if this has been covered but guy on Disco facing big bill for a winch after leaving tyre to be repaired on an 11 week old Disco Shocked
http://www.disco3.co.uk/forum/topic80879.html
LR refusing warranty claim as they say he should not have used winch without a wheel attached and as we share the same winch this is a bit worrying Sad
Handbook states
Quote:
Note: If, for any reason, the spare wheel is not
to be fitted back in its hoist, the wheel hoist
should be rewound as follows.
Position the lifting lug level on the cable and
wind up the wheel hoist mechanism until it
clutches out.
So what is the problem Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #349755 Wed Jul 04 2012 11:25am
Thanks for this.
This is madness - what are you supposed to do when you leave the spare to be fixed.
VERY VERY BAD SERVICE LAND ROVER - SORT IT OUT!!! 2005 Zambezi TDV6 - Gone but not forgotten
Post #349762 Wed Jul 04 2012 11:57am
mike21
2009 Range Rover Sport TDV6 HSE Stornoway Grey
I had the same problem when the dealer refused to replace my winch after it didn't work when I wound it up without the spare wheel in place (it didn't clutch out), they said the same that it was my fault and not covered under warranty. I had to get in touch with land rover direct and sent them an email copy of the handbook page, they then relented and renewed the winch, annoying and time consuming but worth the trouble Thumbs Up 2019 BMW X3 2.0i M Sport in metalic black- Brilliant
2014 Mitsubishi Outlander PHEV Atlantic Grey, replaced with 2018 Frost White Outlander PHEV, can't fault em - now gone
2012 SDV6 HSE in Orkney Grey, Privacy Glass & Side Steps (notice a theme)! - Even better but now gone
2009 TDV6 HSE in Stornoway Grey, 20" alloys, Privacy Glass & Side Steps - Fantastic! but gone
Post #349813 Wed Jul 04 2012 8:03pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
LRA coiled mine up and cable tied it to something under the car.
Nik. 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #349825 Wed Jul 04 2012 9:11pm
Makes me glad my spares in the boot, better read the book though just in case there's a special way in which to slid out the floor Shocked
LANDROVER this is a joke Exclamation Exclamation
Post #349826 Wed Jul 04 2012 9:15pm
MAW
IIRC my first RRS had a tangled winch problem - replaced under warranty but they cable tied the winch cable to something around the towbar socket rather than winch up without load - seemed odd ....
Poor design and still there 7 years on Confused
Post #349834 Wed Jul 04 2012 9:51pm
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Guess I was"lucky"- left spare to get changed overnight at the fitters wound it up empty and found no problem
2011 HSE Thumbs Up
Post #349931 Thu Jul 05 2012 10:29pm
muddywheels
Milk Float Man
Guy on Disco now sorted under warranty but beware Bow down
D4Comm wrote:
Well, was at the dealers this morning.........
Took the manual in and turned to p.227. They took a photocopy and said they would ring LR once they'd inspected the winch.
45 mins later, keys were handed back to me, winch replaced under warranty!!
Service adviser said that they had read the notes in the manual and according to those I hadn't done anything wrong.
Also said they hadn't seen this advice before? The advice that they have been given by LR is completely contrary to what my manual says hence the suggestion over the phone that I had mis used the winch.
They said they would pursue the claim with LR using the evidence from my manual.
I mentioned the suggestion of connecting the wire to the rear tow eye if a spare wheel was not present but this was advised against as it wouldn't be a 'straight' pull if the winch was wound in. They suggested not winding the winch in but to cable tie it around rear cross member until spare wheel is ready to be re fitted.
Happy with the outcome anyway!! Thumbs Up
Post #350513 Thu Jul 12 2012 3:19pm
pulley39
2006 Range Rover Sport TDV6 HSE Java Black
i am truly stunned , im having the "rr jitters " at the moment ie everything going wrong ... seriously can not believe that this is a genuine problem ???!!!!!!!!!! how can such a simple winch be so poorly designed ... at least now i know that the thing is shagged and and needs replacing ..thanks Neutral
Post #350714 Sun Jul 15 2012 10:44am
pulley39
i see new ones on ebay for around 100 quid ... anyone ever replaced one themselves ?
Post #350715 Sun Jul 15 2012 10:46am
essexfarmer
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Replaced the one on my previous Discovery and can't think the RRS would be any different, took about twenty minutes and cost eighty quid from the main dealer. 12MY RRS Orkney Grey HSE Lux
12MY FF Santorini Black VSE
Post #350718 Sun Jul 15 2012 11:09am
pulley39
thanks will give it a go
Post #350734 Sun Jul 15 2012 2:40pm
pulley39
very easy to replace the winch .. literally 6 screws and thats it .. a word of advice .. amazingly the winch was cheaper to buy from main dealer than on ebay so make sure you double check
Post #351531 Mon Jul 23 2012 4:39am
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
My wheel winch seized last night after I'd wound it up without the spare. I took it to the dealer today and expect a warranty officer to call me later with news of whether they'll fix it under warranty.
I showed them this thread so expect a good reply.
He went onto say that they will not honor warranty claims if a power tool has been used to lift or lower the spare wheel. Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #355324 Sun Sep 02 2012 8:37am
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
get a wheel protector, suspect there weight would casuecthe winch to operate without a spare. If you took some fog and put it in a jar, would it be missed.
Post #355337 Sun Sep 02 2012 10:39am
