![]() | Home > Off Topic > How Easy? |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
Frightening I program keys for a living all above board I might add and the main problem is the key programmers have been copied by the Chinese and are available on the Internet for peanuts. It's killing the locksmith trade and also allowing the scum bags access to cheap programmers. 16 model year yulong white autobiography
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Unbelievable |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Makes you think doesn't it |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
Perhaps the answer is that the ODB port should be inaccessible and behind a physical lock e.g. behind a locked flap in the engine bay or under the boot floor. Use the car's physical key to unlock the flap. That way, a garage can still access it because the owner will let them use the key but scum can't get to it even if they break a window. 2012 SDV6 - it's missing a couple of cylinders
^^^ Good idea |
^ Just what I was going to suggest..
sjuggins Member Since: 18 Jun 2012 Location: Bedfordshire Posts: 25 ![]() ![]() ![]() |
It's becoming more common to employ the services of ex-hackers in the IT security arena to perform penetration testing and find exploits in companies network security. Would make perfect sense to do the same thing in the car security arena.
