Home > Maintenance & Modifications > Cleaning / Detailing
rigsby
Hi, I have cleaned my RRS more than i have cleaned my last 6 cars put together and I've only had it 7 weeks. What is happening to me ????? Confused Confused Confused
I have read lots of info on here and the detailing world forum about cleaning my Sport. I have chucked my sponge and chammy leather out and got a lambswool mitt and a microfibre towel, bought a power washer, now a foam lance, even use two buckets (if i remember to use the 2nd one). Got all the chemicals i can think of and as you can tell i'm becomming hooked. Truth is i've got all the gear and no idea!!!!!!!! Rolling with laughter Rolling with laughter
My RRS is Buckingham Blue so shows all the marks and even when i have foamed it, washed it dried it and used a Quick Detailing spray you can see lots and lots of faint water marks(and loads of tiny scratches) Crying or Very sad Crying or Very sad Went to see a Detailer and he gave a price to sort it out but is this something that I can do myself (no experience) or should i spend some money with him and get it done properly? Very Happy Then once it has been done is it easy to keep it looking good or will it look like it does now a few months later? Big Cry Big Cry Big Cry
Anyone else taken the plunge and done a good job or bol Censored ed it up and regretted trying
welcome any of your thoughts regards Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #349065 Thu Jun 28 2012 7:49pm
Personally i would let the detailer sort it out for now, then get inside his head and ask him how you need to keep it looking good, he will give you all the advice and tips you need. Thumbs Up Also Nick pinks or beano will be along soon to give you a few tips on what products to use and how to use them properly. Thumbs Up
Post #349070 Thu Jun 28 2012 8:12pm
rigsby
cheers Ady MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #349071 Thu Jun 28 2012 8:15pm
It depends on what your after, pro detailer grade mirror looks finish or a freshen up lose a few swirls
First it's not a easy job to do, you'll have a lot of preparation and a long time working on polishing, I think all too often someone buys a machine polisher and thinks it speeds up the polishing, in fact doing it right takes more time than what you may do with a bottle of polish and cloth
Firstly, you'll need to wash, getting into gaps and rinse, clay the car to remove paint contamination, de tar and wash all over again and fully dry the car. (this took me a full day)
Tape up the panels, to prevent grit/dirt been pulled in, Polish with the safer Dual action your going to be working in small section, and move it on once your desired finish is sorted, (how toos can be found on DW or YouTube) but you'll be at this all day too and again to refine the panels if need
Polishes it's a mine field, Meguirs Microfibre kits a supposed to be good, and so is the foam pads and GTechniq P1
But when you have bought a DA polisher the pads the polishes and the last protective layer be that wax or sealent, your not looking at much more for someone else to do it and you maintain it after
Post #349075 Thu Jun 28 2012 8:31pm
rigsby
Thanks npinks, i think it sounds a bit involved for me to have a go at especially with limited time, plus i will need to buy a polisher and all the polishes/pads etc. I have been quoted £550 for paint correction, leather clean / feed and interior done as well, does this seem a sensible price? MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #349077 Thu Jun 28 2012 8:39pm
Rigsby, can't really add much more than Nick has said Bow down
Could be worth canvasing a few detailers and comparing prices just to make sure you're happy. Sounds like you've already been over on Detailing World, but check out some of the detailers near you and see their work in 'The Studio'. Thumbs Up
There's a sticky thread on there that has all the detailers by location. Smile ON THE WAY: BMW F21 M140i
Post #349112 Fri Jun 29 2012 6:49am
rigsby
Cheers Beancounter, just registered on DW so think I,m on the slippery slope, no going back! MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #349113 Fri Jun 29 2012 6:53am
Yup, it does pay dividends though. I've really not had that much time recently to keep the car looking clean, but I always foam, rinse, foam again, wash, rinse then dry. Sounds a ball ache, but the paint has virtually no marring as the snow foam and rinse allow all the grit to come off before I touch it with a mitt.
I also sealed the car with Gtechniq C2 and C1.5 when I got it and it makes washing a doddle. Cool
Once corrected, you should be able to minimise any damage with a decent wash technique, you just need to decide if you sub out or do it yourself Thumbs Up ON THE WAY: BMW F21 M140i
Post #349116 Fri Jun 29 2012 6:57am
rigsby
Thanks Beancounter,
Think it may be wise to have it done properly to start with, I know its £550 but by the time I spend £200 on the stuff I need it doesn't sound quite as bad. The guy I went to see was a gut called Paul Harrison in Bosham. He had a RRSPORT there that he had just completed and it looked wonderful. Mind you I thought mine looked good two weeks ago !!! Then someone pointed out all the little scratches Mr. Green
When you do your 2nd snow foam do you rinse that off then add shampoo and wash or do you use the mitt straight on the foam ?
Post #349130 Fri Jun 29 2012 9:38am
Sounds like a plan, have seen his work on DW Thumbs Up
No, I don't rinse off the second snow foam, I tend to just make it a slightly more watery mixture (turn the dial on the top of you foam gun) then just wash with the car shampoo.
Probably a bit overkill, but works for me. Thumbs Up
To be honest, once you get it corrected and you get some decent protection on it (be that wax or sealant) washing will be so much easier.
As I mentioned I've been using the GTechniq range (C2 and C1.5) and I have to say, their ability to resist dirt is Bow down and they are a doddle to apply if you do fancy topping them up. Thumbs Up ON THE WAY: BMW F21 M140i
Post #349131 Fri Jun 29 2012 10:04am
glad my reply helped a little
there is a section on DW for sponsored details, you might fined others in your area to get a quote from too
Post #349133 Fri Jun 29 2012 10:15am
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
..."The guy I went to see was a guy called Paul Harrison in Bosham."
Hi Rigsby, - I've heard good reports about Paul from others not on this forum and seen the results of his work. I believe he is highly recommended.
Thumbs Up Carl
Post #349203 Fri Jun 29 2012 9:50pm
rigsby
Thanks V8SC that's good to know, bit concerned letting someone loose on my paintwork, although the one he had in at the time was in cracking condition. He seemed to know what he was talking about. Mind you he could have told me anything I would have been none the wiser Rolling with laughter Rolling with laughter MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #349205 Fri Jun 29 2012 9:59pm
Paul@DCC
Was good to see you and the car the otherday Wink
Let me know if you need anymore info etc or what to get it booked in, I'm Paul Detailed Car Care (*hampshire detailer* over on DW Wink
Paul
Post #349932 Thu Jul 05 2012 10:03pm
rigsby
Hi Paul and welcome to the forum.
Sorry I couldn't remember your company name when I posted, but found your card since.
I'm sure there will be plenty of questions on here if other members know who you are and what areas you cover. Not sure what the rules are on the forum with regards to businesses etc but welcome along anyway mate
Regards Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #349944 Fri Jul 06 2012 9:09am
