Home > Technical > Gearbox shunt into first gear??
bhoy67
2005 Range Rover Sport Supercharged Java Black
Been happening now for a while, as im driving and coming to a halt ie lights, roundabout etc with my foot on the brake slowing to a stop the car shunts a little as it selects a first gear? Is there a solution for this ie software update or even replacing oil n filter in the gearbox?
Post #348665 Tue Jun 26 2012 8:21pm
KaminskaJacekstreic
United Kingdom 2012 Range Rover Sport SDV6 HSE Fuji White
HI ,I had the same with my X5 and bmw 5 series ,its just gearbox,with X5 I end up changing gearbox,5 series I sold very quickly Big fun of RRS-my one WHITE-RED with wide body kit plus RS alloys all from KAHN
Post #348677 Tue Jun 26 2012 9:11pm
There is a software update that "may" fix this...
It sounds more like you need a gearbox flush Thumbs Up RRS gone
Post #348714 Wed Jun 27 2012 9:12am
SRE
Spain
Not quite sure what you mean by shunt, do you mean backlash / slack in the drive train???
If going slowly virtually stopping and pulling away, do you get what is felt as backlash / slack in the drive train, if so, try and leave the car in sport mode, if the backlash / slack is no longer felt, then I understand that there is a software patch to remedy this.
Remember the car never selects first gear only second In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #348720 Wed Jun 27 2012 9:29am
JUCOTT01
This was happening to me a while ago
Low gearbox oil level
My oil cooler pipes fractured leaking fluid, it continued to get worse until it jumped about the box and went int limp home mode
All sorted under warranty
New oil cooler
new pipes
new gearbox oil
Thumbs Up RRS MY11 BALI BLUE OVERFINCH
Post #348838 Wed Jun 27 2012 8:29pm
JUCOTT01
New oil cooler
new pipes
new gearbox oil
Post #348839 Wed Jun 27 2012 8:30pm
bhoy67
i suppose there is no harm in changing the fluid and filter first, surely all gearbox oils should be changed at some point?
especially after 60k
Post #349351 Sun Jul 01 2012 4:04pm
The biggest problem is LR transmission oil is £20 a litre (do not be temped with anything other than this) RRS gone
Post #349390 Sun Jul 01 2012 9:09pm
shakeapaw
as LR do not make Oil, you can always buy from the firm that makes it, i believe its Millers, but could be wrong 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #349947 Fri Jul 06 2012 10:40am
The oil is refined by Esso I think
Many gearbox centres will insist it to be TYK500050 otherwise you risk all sorts of issues
Here is the genuine stuff
http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...3cc240d0e5 RRS gone
Post #349958 Fri Jul 06 2012 1:46pm
