Home > Maintenance & Modifications > Detachable Tow Bar Headache
arbee
United Kingdom 2011 Range Rover Sport Supercharged Santorini Black
Hello - wondering if anyone can help here.
I have a detachable tow bar that used to fit and work nicely with my 07Supercharger.
I tried to fit to my 11 Supercharger and the bar seems to lock in but the green handle does not fully snap back in place and it is then not possible to rotate the key to extract it.
As far as I know there has been no design change - has anyone come across a solution for this please ?
Confused
arbee
Post #348551 Tue Jun 26 2012 8:53am
Have you tried the 'fix all' solution of spraying a little WD40 on it to loosen anything that maybe stuck ? ON THE WAY: BMW F21 M140i
Post #348552 Tue Jun 26 2012 8:54am
arbee
Thanks Beancounter
Yes tried WD 40, jiggling and liberal application of foul language so far - all to to no avail !
Post #348553 Tue Jun 26 2012 9:07am
muddywheels
Milk Float Man
Suggest a trip to the dealer and as you are still under warranty a bit of goodwill should be in order even though tow bar did not come with vehicle Very Happy Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #348554 Tue Jun 26 2012 9:13am
Is the tow bar in the car, or are you trying to do this off the car Question
I only ask, as there is a small steel release pin at the back of the tow bar that allows the mechanism to work once you insert it into the car. Idea ON THE WAY: BMW F21 M140i
Post #348555 Tue Jun 26 2012 9:14am
arbee
Thanks Guys -
yes am trying to do it in the slot. Basically it locks into poistion and takes my weight - But the green knoob does not come all the way back to allow the key to be removed and a small piece or red/orange can be seen to show it has not correctly loacked in.
I can get the thing to work out of the slot so it is as if something is not locating correctly to position it.
Vexing..
Post #348566 Tue Jun 26 2012 10:22am
Have you checked there's nothing stuck up inside the car part? Did it have the red 'cover' in it ?
Might be just as easy to pop and see the dealer to be honest as it seems you've exhausted most routes:
Common sense, brute force, swearing, WD40 etc Laughing ON THE WAY: BMW F21 M140i
Post #348567 Tue Jun 26 2012 10:33am
sayers
i have this same issue, it will be LR job on thursday when the car goes in for being VERY sluggish on pull off and other bits.
Post #348601 Tue Jun 26 2012 2:15pm
toshers
Scotland 2008 Range Rover Sport TDV8 HSE Stornoway Grey
The lock had seized on mine. The only way I could get it off was to strip down/disassemble the lock, actually worryingly easy! I was then able to get it off the car. I'm not about to publish how I did it on an open forum, but if you pm me I'll forward a procedure if you're interested.
Post #348690 Tue Jun 26 2012 10:32pm
MAW
Had similar between old and new sport. Spray or grease socket to aid removal. Insert tow bar and whack northwards and it shold lock into place. I put it down to a dry socket ... Smile
Post #348775 Wed Jun 27 2012 2:14pm
muddywheels
Milk Float Man
Had to read this twice thought I was on the wrong website for a minute Rolling with laughter Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #348785 Wed Jun 27 2012 3:36pm
MAW
Thought that when I was writing but it was tricky enough on the N8 as it was Laughing
Post #348831 Wed Jun 27 2012 8:14pm
Kiwi Graham
New Zealand 2007 Range Rover Sport TDV6 SE Stornoway Grey
Just a long shot and a bit of a thread highjack;
Does anyone from Kiwiland have the optional 'convertable' tow hitch that they dont or wont be using?
Happy to do a trade with cash for the usless to me 50mm one.
Graham
Post #348843 Wed Jun 27 2012 8:50pm
