![]() | Home > General > HEAD LIGHT adjustment of Europeon travel?!? |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644
Mine is a MY10 and says adjust lever behind lights in handbook |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
There is a sliding lever inside the headlight to the side of the xenon bulb. RRS gone
| Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146
U have to remove the headlight unit to access it... Range Rover Vogue ‘17 TDV6
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
1. Open the bonnet
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
Wow! If only I had posted the same question to get such a detailed reply from RRSTDV8 before working it out myself! Would have saved me a lot of time. I knew all the steps but the handbook makes it sound so easy. I was worried about using too much force fearing I would break something. I would like to share my experience too.
It does require a lot of force especially if the grille hasn't been taken off for a long time and I can imagine damaging the paintwork could be quite easy.
The catches were too tight and I was also tempted to use a screwdriver to lever them up but refrained due to the reason RRSTDV8 described. Ended up using pliers to grip the top of the clip and pulled vertically. Worked for me. Was still unable to move the headlamp unit out because I had pulled the catches all the way up (this is what I thought the handbook suggested). You have to look closely and stop pulling when the holes align with the studs.
The lever is indeed very flimsy (and feels cheap quality tbh at least in my 2009 bi-xenons) so be very careful. |
| andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 348
Andrew Kennedy |
Andrew Kennedy |
Thanks for yours..all is now clear! A couple of questions you might be able to help on.......The ref: on my lights reads XBC5017932N - would these be Xenon lights?? My car was made to European specs. (left hand drive). I have the hand book Manual in English and French and in both books it shows the default light adjustment in the UP position which is odd if the same light fitting is used for all vechiels?? Andrew Kennedy |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441
Hello Andrew
| Big Martin Member Since: 13 Feb 2012 Location: Kent Posts: 6
If you take off the round cover on the back of the headlight (without removing it), it is just possible without stripping the front of the car. The little lever sits to the right of the connector on the back of the lamp (to the right as you are sitting in the car looking forward), once you have Identified it with a torch, its really easy to do, without looking,once you get to the ferry. When I'm queuing up waiting to get on ferry/train, pop the bonnet and it is done in less than a minute, I go France at least once a month!!!
Just had a look under the bonnet - very simple to change. MANY THANKS Andrew Kennedy |
| Mail Order Ride Member Since: 28 Feb 2009 Location: UK Posts: 131 |
Sorry for the thread resurrection but I just cant figure this out
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
The levers are both a bit of a fiddle especially the RHS.
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
^^^ Nice idea. |
| All times are GMT |
