![]() | Home > Technical > Suspension dropped over night and squeaking front suspension |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5643 ![]() ![]() |
There have been others with this issue - look here
ckevin Member Since: 21 May 2012 Location: china Posts: 10 ![]() |
i have the exact same issue with my TDV8 , not solved yet. |
RRSTDV8DK Member Since: 26 Mar 2007 Location: cph Posts: 67 ![]() ![]() ![]() |
Hi Muddywheels - did see that post, but in my case the suspension is all level when engine is on and when driving, no warning on dash or anything.
Possibly a sensor fault |
jundrill Member Since: 18 May 2011 Location: Epping Posts: 64 ![]() ![]() ![]() |
I had the exact same project. I had Brown Church change the offending's side height sensor (back near side) but it made no difference. I then took it back in and they re-set everything and its been fine since.
Hi Jon
No, I take all what I said back. I went out to the car this morning and the back near side was down......
Ok - sorry to hear that
When I got mine inspected there were no air leaks and the error log was blank, really odd (although they changed the senor, but it made no difference, I still had the problem).
I missed out the bit that by changing the front near side senor someone else with the same problem managed to resolve their problem..... |
Ok - the dealer just called and said it is a cross valve that needs to be changed - that will be £600 ... RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 702 ![]() ![]() ![]() |
Oooof Java black 2006 |
