![]() | Home > General > Towbar on a rr sport hst |
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Yes, detachable tow bar is the way forward so you can keep your HST looks when you're not towing.
| B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450
check at rear of your car, if one was fitted previously then the electrics may still be there, and you'll just need a tow ball (£150 on ebay), if no electrics, a simple kit is about £100. Tow balls are removable with a security key. |
| RRS-KID Member Since: 20 Jan 2012 Location: Derbyshire Posts: 16 |
Ok great! How much is a detachable one? And where from?
they're all detachable, and the tow bar is already fitted to all RRS's, just the actual ball hitch and electrics are optional. Try ebay for the tow ball and electrics at my above prices |
Great, I was just wondering if they can be fitted as HST has a different bumper.
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Yes it will
HERE'S A PHOTO
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
RRS-KID - use a 5p coin (not a screwdriver - too sharp) to gently turn the fixings though 90 degrees, and don't apply to much pressure when replacing the cover else you'll bur the heads over, they're only plastic |
| dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851
Also open up the panel in the boot on the RHS, you might get a pleasant surprise and see a tow bar in there.....I certainly left mine in place when I sold my HST to Marcus!
| kilsbm Member Since: 18 May 2012 Location: Walton-on-Thames Posts: 12
I user the detachable one, really easy.
| All times are GMT |
