![]() | Home > Maintenance & Modifications > Help, water in driver's footwell without a sunroof ! |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Leaking aircon or damaged to the underside |
| SkyWalker Member Since: 04 Sep 2009 Location: Marbella Posts: 541
I had the same in one of my previous cars.
| 1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530
Thanks for your suggestions, but I'm still stuggling to find the source of the water coming into the footwell. Any more ideas would be greatly appreciated |
| ngins Member Since: 06 Mar 2010 Location: UK Posts: 72
Hi. Did you ever fix this? I have the same problem which I think is causing the wiring loom to fail on the driver's side as the loom is underwater....... MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras |
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380
Hi, just to start in the right direction , had it been raining or hose pipe on the roof after washing ?? if it had then it will almost be certain that it is the slots behind the A pillar cover. I had this on mine and i believe it is a very common problem, but an easy fix if it is. |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
As suggested - quite likely the 'A' Pillar leak issue. If you follow this link it is to a document (pdf) with all the information you need. http://www.rrsport.co.uk/gallery/albums/us...0pdf~0.pdf 2008 MY Java Black TDV8 HSE
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563
What ever you do I suggest you fix it quick as water and wiring don't mix. Recent CAR SOS programme showed what happened to a Porsche when its seat electrics got wet. Not a pretty site inside. Robin
Thanks all for the info and link. Actually my seat has decided to stop working which led me to lift the trim under the door kick panel which led me to discover the water. Dried it out completely Friday and with rain on Saturday it was full of water again today so will get a kit and see if that fixes it. Then only the seat electrics to try and fix........ MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras |
| All times are GMT |
2005 RRS HSE 2.7 TDV6
