![]() | Home > General > HEATING & VENTALATION query |
I've never really taken much notice.....
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
I'm not sure |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
i thought it was semi auto in that mode, the air con is active, but the fan speed is not controled by the computer, you set it maually 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9074 ![]() ![]() ![]() |
Top light is on when the fan is being controlled by the climate control system. Turn the fan speed control manually and the top light goes out and the fan speed lights around the speed control light up appropriately.
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 338 ![]() ![]() ![]() |
RRSTDV8 Many thanks for your info, just to summerise, if the ECON button if press ON the aircon will not be active. With the ECON on this would allow the fans to be regulated to bring through warm air from the engine/rad area? With the AUTO pressed ON with either one or both red lights on the aircon will come on if situation demands. Andrew Andrew Kennedy |
Econ turns off the air conditioning and gives you external air in its raw state. It comes from the bottom of the windscreen, not the engine bay / radiator area. If you want warm air, just turn up the temperature dial... 2012 SDV6 - it's missing a couple of cylinders
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Auto - Termostatically controls the cabin temp.
Many thanks - I now know exactly how the systems works (not very well explained in the handbook). They do say in the handbook that running with the ECON on helps fuil consumption - any thoughts?? Andrew Andrew Kennedy |
Running in Econ mode switches off the compressor so the engine doesn't have to provide power to run it. Less power required from the engine means less fuel is burnt hence improved economy. 2012 SDV6 - it's missing a couple of cylinders
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
With my BMW from tons ago, running with AC compressor turned off was strongly discouraged - could lead to component failure, apparently. I am guessing the RRS suffers no such risk. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
AC systems need to be run at times to keep the system "lubricated". ISTR the advice was 30 minutes every 30 days to ensure seals etc were kept in good condition.
The problem with AC climate control in the winter is that once it gets to temperature, say 21C, it starts to waft cold air into the cabin to 'maintain' a comfortable cabin temperature, thus making you cold. My missus forbids the AC button to be on in winter. Not my choice. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
