![]() | Home > Technical > Power loss? 2006 TDV6 HSE |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Might be an EGR failure..power loss below 2k rpms is usual symptoms.
| Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564
Thanks awd |
If it does turn out to be EGR(s) then as a pre 2007 car, you can fit an EGR blank off kit (£12 off ebay for the kit) and 3 hours of a mechanic's time.
In that case, I hope it turns out to be an EGR issue as they seem like relatively quick and low cost fixes. Is there any way of checking this is the issue before it goes on or is loss of power the only symptom? LCFC. Receiver of threatening letters from Overfinch. |
Yes there is a way
| tonser Member Since: 17 Jan 2006 Location: Cobham, Surrey Posts: 244
I had the same issues as you on my 2006 tdv6 last year, and blocking the EGR valves remedied it - in fact the car drove brilliantly after it. I bought the kit from Bells for about £48 and it took me 2 hours to fit it.
Thanks guys this is great info.
Yep that's the kit |
Thanks awd man, your help has been gold thus far buddy!
