| RRSPORT.CO.UK | ||
|  | Home > General > My rrs 2011 has problems at service |
| jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210      | If its only one year old (2011) then yes, it should be fully covered under the warranty.
|  Mon Apr 23 2012 7:59pm |
| RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139      | Yes has manufacturers warranty for 3 years I believe. This is my second rrs never had this kind of problem, it seems slow to change up from 1st to 2nd? Any thoughts. RRS | ||
|  Mon Apr 23 2012 8:04pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Are you using drive when this happens or using the flappy paddles   | ||
|  Mon Apr 23 2012 8:08pm |
| RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139      | That would be drive it must be the 2012 or supercharged with paddles....I presume? RRS | ||
|  Mon Apr 23 2012 8:09pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Flappies have been an option from 2009 onwards but became standard from the 2012 model, if its in drive and you are setting off from standstill then you motor is setting off in 2nd gear, they all do, thats why you think its slow selecting the next gear, its actually changing up to 3rd not 2nd  due to the torque of these diesel engines.   | ||
|  Mon Apr 23 2012 8:17pm |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441      | rrs sc does not have flappy paddles, but it does have a grear stick rather than the dial. (i personally dont like the dial and paddles) I checked in the dealers last week. The sc does not come with the 8 speed box. is yours diesel or petrol sc?
|  Mon Apr 23 2012 8:21pm |
| RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139      | Thanks Ady sounds like you know what your talking about. The dealer also tested it after the software downloaded and said its not right it's as if it's stuck in 1st and will not go into 2nd until revs ars higher. It wasn't behaving like this when it was new, ie 6mths ago? RRS | ||
|  Mon Apr 23 2012 8:22pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Craig, you could try changing your gear in command shift see if it changes gear quicker and as it should   | ||
|  Mon Apr 23 2012 8:24pm |
| RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139      | Ady I you referring to pushing it into sport with the gear stick to the left, is this command shift? I have been driving short distances of late and I never drive it like I would a supercharged....more like driving miss daisy! Strange they kept it in.
|  Mon Apr 23 2012 8:37pm |
| RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139      | Its a diesel shepp RRS | ||
|  Mon Apr 23 2012 8:39pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Yes craig, slip it into sport mode it will show "S" on your dash, push it forward and it will select 1 then when you pull it back it will select 2 and so on   | ||
|  Mon Apr 23 2012 8:47pm |
| RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139      | Many thanks Ady sound advice especially when I wasn't aware of your points. Cheers.
|  Mon Apr 23 2012 8:54pm |
| RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139      | Ady are your exhaust pipes all one or tips? The whole car is 10/10 RRS | ||
|  Mon Apr 23 2012 8:58pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Thanks craig   | ||
|  Mon Apr 23 2012 9:09pm |
| Posting Rules
 This might go some way to explaining your problem.
 This might go some way to explaining your problem. give it some stick now and again when its warmed up and blow them cobwebs off it.
