![]() | Home > Technical > Intermittent HDC Fault On Startup |
| firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461
start the car, with no brake pressed, does it do it then, if not press the brake see if that fires it, i had it a few days ago tuned out to be the brake switch, simple fix.
| chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219
It does it without putting your foot on the pedals. |
| DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045
Battery and/or alternator goosed. If it's the original battery it's telling you it's had enough. |
Ok thanks guys.
If it was me I'd stick to the OEM one. The D3/RRS alternator works at a higher voltage than normal some batteries can't take that. The LR ones have a 3 year warranty and you can get 10% off with Allegance Discount. |
OK guys,
| Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282
I got this falt when the battery was knackered, changed the battery and everything was fine.
| mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116
hi chapman.still can not post photos..! please advice me again,thanks |
Photobucket.com
Big Ken:-
so chapman,what you think.? SNAP |
thanks for help,bingo |
Looks spot on mate.
| All times are GMT |
