| RRSPORT.CO.UK | ||
|  | Home > Technical > Tyre and wheel comparability |
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690    |
 Guys
|  Sat Mar 24 2012 3:39pm |
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690    | I was also thunking the same as seem very very low profile. They are of a P36 (larger range rover vogue I think that is) and doing a trade in for my HST 20 inches with Continental tyres. The others have 295/30/22 on Toyos TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
|  Sat Mar 24 2012 7:14pm |
| Ballsy Member Since: 19 Jan 2012 Location: Fife Posts: 160  | The profile is only 10mm of a difference so it shouldn't have much of an effect but alloys are generally expensive so any extra protection you can give them the better.
|  Mon Mar 26 2012 7:10am |
| Posting Rules
  you will destroy your wheels at the first pot hole you run over
 you will destroy your wheels at the first pot hole you run over   knacker your suspension in no time at all
 knacker your suspension in no time at all   minimum 35 profile on 22's i'd recommend, i'm sure you know to check the load weight of the 22's
 minimum 35 profile on 22's i'd recommend, i'm sure you know to check the load weight of the 22's   and i havn't heard of any 22's not fitting over brembo's as long as they are for a RRS and are the correct offset you should be fine.
