![]() | Home > General > Flat battery |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
HI
If it was upto me I would insist Lr put your email and the forum address in the owners manual as a
Try a reset, disconnect both your battery leads and hold them together for several minutes then reconnect, positive terminal first |
Finally some good news, having been messing around with different things trying to resolve suspension issue
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 154 ![]() ![]() ![]() |
Just one tip the alternator on late 2009 cars on do not fully charge the battery once is has been drained. It MUST be charged with a battery charger, and one of the newer ones. The old trickle chargers don't work properly with the newer batteries. It is all about fuel consumption/power management, this is not unique to LR most new cars are the same. See my post re flat battery, the roadside assist and LR reckon you can drive the car to the moon and it would not fully charge the battery, once it has been drained significantly. They adivsed that typically once drained the alternator will only take it to 60% charge, enough to start it and trick you into thinking it was good, but in fact, just waiting for a small drain to catch you out. SWMBO owns this car I get to drive occasionally |
I think thats a bit harsh...do you think batteries will supply an indefinite power supply when there is nothing to re-supply it?! Or that you could plug in a microwave in the boot and it will be all ok to cook a meal...do you now how inverters work over 12v supply for devices? personally most modern cars, with a high amount of electrically controlled systems depend on the battery to be in a good state and im sure the manual has a bit on it. Mike 2014 Facelift Discovery |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
+1 ![]() modern heated seats will kill a battery in a few minutes if the engine is not on ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
