![]() | Home > General > New RRS |
Welcome Zango - Personally I would go for the diesel, I note you're in London and TBH the diesel's running costs are so much less but then this might not be an issue with you. The SC is great but do you need the power? Test drive both and make your mind up then but both engines are good.
| andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155
I'm sure you will get a lot of technical advice from the esteemed and knowledgable members here....
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391
if you are planning to keep for 10+ years then the biggest consideration will be the air suspension (same for a lot of modern cars). Can get very expensive to replace/maintain.
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690
Why not get one of the last TDV8s built? I have a 2008 model and whilst you could go for a newer one th engine is regarded as the best diesel ever built and will last for ever.
+1 last TDV8 buying - I have a 10 plate, but I think you can get a 60 plater? ============
the TDV8's are known to chew alternators |
yes the TDV8 will eat anything in its path |
| SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1828
Thats funny as i remember hearing of a few TDV8s that have gone pop. SVR 2018 in Santorini Black. |
poor owner care |
Could be. |
| All times are GMT |
