![]() | Home > Technical > Vehicle will raise when compressor cooled? |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
A hot compressor? 07MY RRS TDV6
Most probably compressor has over-heated due to repeated height changes.
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816 ![]() ![]() ![]() |
I tried to go in access and it wouldn't. Kept going up into off road saying lower once cleared obstruction |
Maybe there is an obstruction under the RRS?
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
or there is a pressure leak in the system and the compressor is having to run continuously to keep the pressure up to the desired height sensor signal. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
has he lowered the suspension?
