![]() | Home > Technical > Garage ramps? Advice please |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
It won't harm the air suspension, but make sure the lifting equipment locates under the chassis,preferrably at the holes specifically for jacking at......... the body does not have any jacking points and will be damaged if he tried to lift it on that, also, do not let him lift it under the suspension compressor. |
I'd heard you must leave the tailgate open when jacking to stop the car from trying to auto-level RRS gone
Jeeeppy Member Since: 17 Jun 2011 Location: Garden of England Posts: 39 ![]() ![]() ![]() |
Or put Hazards on I believe |
That doesn't work awd, you need to leave a door open really when using a jack, but having said that its different again when you are lifting the whole vehicle, when my car was in at the dealers using the ramp described above i think they put the suspension in extended height then lifted the car on the ramp, because its being lifted square the suspension doesn't try to level itself. Thats my understanding anyway. Last edited by Ady 555 on Wed Feb 22 2012 12:30pm. Edited 2 times in total |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5643 ![]() ![]() |
The handbook says the vehicle must be in extended height when jacking so that would make sense |
JoeRRS Member Since: 04 Feb 2011 Location: Eaglescliffe Posts: 217 ![]() ![]() |
My garage usaly leave the tailgate open and puts the hazards on then once back on the ground you just need to reset the suspension. |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
Cheers guys |
