Home > General > Bluetooth conection
Jimmy Longlegs
Bluetooth conection
Hi, does anyone else have trouble with Bluetooth? I have a 2006 RRS HSE but my I phone 4s won't pick up the Bluetooth. Is there any fix for this?
Post #331960 Fri Feb 10 2012 9:25pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
it has been known to have some issues. A 57 plate I had refused to pair with a blackberry until I had changed the actual software on the phone. Search my posts and good luck Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #331998 Sat Feb 11 2012 12:08pm
ajp166
I have a 56 plate 2007 and my iphone 4s works fine.. I do have to enter the 2121 everytime I enter though if I want to use it...
Post #332001 Sat Feb 11 2012 12:24pm
Jimmy Longlegs
Cheers guys! Somebody said that the Bluetooth module might need to be updated??
Post #332013 Sat Feb 11 2012 1:24pm
timcom0
I HAVE 2007 TDV6 and mine connects everytime without the need for 2121
just paired it and works fine everytime
Post #332020 Sat Feb 11 2012 1:52pm
rrsboy
is there a setting on the phone, something about auto-connect Question ============
Post #332091 Sat Feb 11 2012 11:37pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
My bluetooth connects fine, but the contacts are not recognised and displayed as numbers, not names... Vadim A.
Post #332101 Sun Feb 12 2012 5:10am
rrsboy
my previous blackberry would only show numbers too, when I upgraded the software (on the blackberry) it fixed it ============
Post #332108 Sun Feb 12 2012 10:30am
Bodsy
Site Sponsor
This'll work for most people (D3/RRS/FFRR) and has the added benefit of giving you Contacts list to scroll though.
http://www.disco3.co.uk/forum/topic53544.html Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #332350 Tue Feb 14 2012 12:19pm
Barnsnape
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Im just about to upgrade my bluetooth unit. I know where it is ie OSR in the boot. I can see it by opening the little hatch. How do I get at it without damaging the boot lining? If I just give it a good pull will it come away with the fittings intact so I can push it home again? 2007 TDV8 HSE, Stornoway, 20" HST alloys + GG ATs, HST body kit and Remap (+45 BHP + 100 Nm)
2002 Freelander 2.4 ES, Black, 16� alloys +GG AT2s
Prev
BMW E63 650
BMW E39 540 (I loved this car)
Post #332401 Tue Feb 14 2012 3:03pm
Barnsnape
To answer my own question - got a big screwdriver behind the lining all came away (and went back) a treat. BT upgarde all worked - my RRS is now usable for business. 2007 TDV8 HSE, Stornoway, 20" HST alloys + GG ATs, HST body kit and Remap (+45 BHP + 100 Nm)
Prev
BMW E63 650
Post #333027 Mon Feb 20 2012 12:54am
ajp166
How did u do the Bluetooth upgrade? I can get to the unit in the boot... but then what did you do?
Post #333029 Mon Feb 20 2012 2:55am
Take a look at the link Bodsy posted about 4 post back Thumbs Up
Involves swapping an upgrade unit with Wiggs of D3 fame and a bit of cash his way Smile ON THE WAY: BMW F21 M140i
Post #333075 Mon Feb 20 2012 11:46am
Barnsnape
While its clear in my mind (did it yesterday), if you can get to the BT unit:
1. Undo the torx screw
2. Note which way round the two plugs go into the base.
3. Remove the small plug in BT unit base (easy to emove- gives more space to work)
4. Remove the big plug in unit base (held by white plastic clip, rotate through 90 degrees, from what I can see this only goes in one way, worth having a good look before disassembly - in the end this was all I had to worry about)
4. Reverse the process for assembly.
I do lots of engineering jobs, the problem for me with this was I was only going to do it once, on my own car. So I was learning trivial things that if I had to do them again would be straight forward. 2007 TDV8 HSE, Stornoway, 20" HST alloys + GG ATs, HST body kit and Remap (+45 BHP + 100 Nm)
Prev
BMW E63 650
Post #333169 Mon Feb 20 2012 5:49pm
