![]() | Home > Technical > 5 Litre Oil Levels |
| Baben Member Since: 14 Feb 2008 Location: Kyalami Posts: 29
Rob is mistaken
| AutobiogRRS Member Since: 15 Feb 2012 Location: London Posts: 3
Thats the problem.. I havent had an oil readin yet.. no matter if I let the car run and rest for 10 mins for the oil to settle, the feature on my dash still will say 'Not available' I can see the 'oil meter' but for the reading itself it doesnt show |
Weird! Are you sure the car is standing on level ground when you try do a reading? If there is a bit of tilt or roll it don't work |
Yeah its real flat the ground.. no inclines.. I reported this to Lookers but seems they didnt do anything about it... |
if it aint working you have a problem, and the stealer needs to look into it |
| chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123
Its also a stupid way of checking the oil, as it requires you starting and running the engine in order to do it. Starting and running an engine that has a low oil level is not clever in the first place. To make that the way to check for low oil is just daft imho. RRS 3.0D HSE 11MY - Fuji White, a few extras. |
