Home > Technical > 2006 HSE Door Mirror Issue
3539david
Hi people,
I am new to the site and have come across trying to research an issue I am currently facing.
Basically my Nearside mirror will not move down when pressing down on the knob- It will move up, left and right using it... But when I try to move it down it doesn't budge.....
I originally thought it may be the motor but when I put it in reverse (Dipping Function Activated) it drops down as its supposed to?
Any ideas? Just to add, the Offside one still functions perfectly both ajusting them with the knob and when in reverse!
Any help will be very much appreciated. Thanks in Advance.
Post #332121 Sun Feb 12 2012 2:45pm
Bob.
Hi 3539david and welcome.
I would have thought the switch would be the first thing to suspect. Selecting left or right brings different contacts into play so the right side down one may be working but the left may not be. The mirror memory module will work independantly of the switch which is about £20.
Hope this helps.
Post #332505 Tue Feb 14 2012 10:33pm
3539david
Bob
Thanks for the advice will give it a try tomorrow thanks,Dave
Post #332872 Fri Feb 17 2012 6:44pm
