![]() | Home > General > Excessive Blue Exhaust smoke when in haevy traffic or idling |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
blue is usually oil, have you checked levels? ============
globe195 Member Since: 26 Aug 2010 Location: Bedfordshire Posts: 36 ![]() ![]() ![]() |
I will check the oil,
blue is oil burning, white is water evaporating - very generally speaking of course |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
I don't know.... but I was just following a TDV8 down the mountain (no throttle) from skiing ..and it was doing exactly that... bellowing loads of blueish smoke intemittantly...... annoying and bloody smelly...
if it was black then it's quite characteristic of diesel engines with turbos |
May be an obviouse question.... but I gotta ask..
I'm not sure what the FBH is?,but it's definately coming from the exhaust.
FBH is in the engine compartment towards the rear of the 'near side'. |
If the oil is 10mm OVER the max mark then get some removed asap
Thanks AWD MAN, I will do that today and hope that it sorts out the problem. 2006 TDV6 HSE Bonatti Grey,Side Steps,Mud Flaps,20" alloys,LED rear lights,2010 style grill,Soft steering wheel,Land Rover carpets and SS pedals |
We overfilled a Laguna once...
