| RRSPORT.CO.UK | ||
|  | Home > Technical > Air Compressor |
| chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123      | I have the exact same fault on the dash and the car is in tomorrow for a new compressor.
|  Tue Jan 31 2012 7:33pm |
| chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219    | Hi Chesterfield,
|  Tue Jan 31 2012 8:28pm |
| chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123      | No idea about reconditioned compressor, but I believe it can be done diy as i read a guide on replacing the compressor just the other day, though this could have been an older model FFRR. I assume the concept is still the same though, its only a couple of wiring plugs and some air lines.
|  Tue Jan 31 2012 11:28pm |
| DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257    | If you have a leak (be it hole in "bag" , line or faulty valve), then your vehicle will be lower than normal after being left overnight (assuming it wasn't left in access mode).
|  Wed Feb 01 2012 9:21am |
| chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123      | That would explain the relay being replaced on mine too.
|  Wed Feb 01 2012 10:00am |
| chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219    | Where is the relay located?
|  Wed Feb 01 2012 2:20pm |
| DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257    | It's in the battery junction box in the engine compartment.
|  Wed Feb 01 2012 4:21pm |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377    |
 Blimey. That looks far too complicated  L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles   RRS S/C factory built HST - Gone 45 others have been and gone! | ||
|  Wed Feb 01 2012 6:22pm |
| chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123      | car back, relay and compressor replaced. Touch wood no reoccurance of the problem yet. However there were days when it workd without a problem even while it was suffering the fault, so may be too early to give a conclusive fix. RRS 3.0D HSE 11MY - Fuji White, a few extras. | ||
|  Thu Feb 02 2012 9:53am |
| Posting Rules
