![]() | Home > Technical > Engine System Fault |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
Electrical issue perhaps? That throws all manner of errors up. Check the alternator and battery... 2012 SDV6 - it's missing a couple of cylinders
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
If it was a TDV6 i'd be suggesting your turbo is possibly goosed. |
toeuk1 Member Since: 18 Sep 2011 Location: UK Posts: 29 ![]() ![]() ![]() |
If only it was that simple. Unfortunately it had a new alternator 3 months ago and the battery is fine. Thanks anyway. |
Just in case any body else suffers with similar problems in the future, I thought I'd update the thread with hopefully the cure.
