![]() | Home > Maintenance & Modifications > EAS control unit anyone used one? |
| shane159 Member Since: 13 Dec 2011 Location: Chesterfield Posts: 76 |
I've just took delivery of my EAS control unit from here:
Each to there own mate, I just feel the car looks better with the wheels filling the arch's (and I'm not a chav) just a personal preffrence. My RR only covers a small amount of miles a week around 40 to 50 so this wouldn't be to much of a issue to be honest. |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203
It's not that I don't think the range looks better at access hight. Whenever I park that's the first thing I do is drop it to access, not because it's easier getting in and out, just cause it looks better. But have you tried actually driving for any distance when on access hight? It would shake you and the car to oblivion. And I would say it would be dangerous to drive. |
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497
Don't you need to re-calibrate the vehicle ride height after fitting this part? |
I'm not sure what exactly the control unit does other than allow you to lower the range. But I would've thought there is no need to calibrate anything as the control unit should do this for you. I remember with the old p38's you used to be able to get a diagnostic lead to plug in a lap top and a program that loaded up so you could set them at the required hight you wanted. I would think this control unit is the same sort of thing. |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
I'm using one at the moment
and no callibration is needed
That sounds good as it goes. So can you explain where it's plugged in and how you use it. Is it something that you leave plugged in and can adjust hight whenever you want or is it a plug in and set it then unplug?? |
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690
AWD Man, is this a simple plug and play module or do you link it into a laptop or something to set it? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx 20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control |
Finally I've sorted mine out, the American based company are so helpful it's unreal.
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441
Hello shane
Locates in the ODB port (under the steering column) with the engine off and ignition on. EAS Menu is then selected via the cruise control buttons on the steering wheel. Once the settings have been changed, turn off ignition and remove EAS (no need to re-insert it Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI Last edited by awd man on Wed Jan 25 2012 3:50pm. Edited 1 time in total |
and is the menu displayed on the EAS or the centre menu on the dash TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx 20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control |
Dash mate
