![]() | Home > General > cruise control - to ACC or not |
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690
It depends what the driving conditions at the time are. Sometimes I love it and others I hate it. Main gripe is the delay in returning to set speed once slowed down by the ACC especially if to return to speed I pull into an outside lane to avoid the slower car. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
| RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169
ACC is a great addition.
| oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359
Just press and release the accelerator pedal, that should tell the car it is OK to go and accelerate up to set speed. This used to work on the Mercedes I had before the RRS. I think the delay is a safety function, imagine the car in front had slowed before joining a roundabout. The ACC would not see a car with right of way approaching from your right, so fast acceleration would be the last thing needed. Just remembered: If the front wheels are not pointing straight ahead this also slows the initial acceleration rate. Last edited by oldcro on Tue Jan 24 2012 9:30pm. Edited 1 time in total |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
I like ACC. Had cruise before and not used it much because it's a pain in traffic having to keep turning it back on if you need to brake - which you often do. Adaptive solves that problem. If you need to, you can still give it some throttle to get back up to speed after a slow down episode. I also use the throttle to soften braking if I can see that the gap is ok but the system thinks it should brake hard. Nice little trick that.
| Mr H Member Since: 09 Sep 2011 Location: Lincs Posts: 427
I personally like the acc, but just wish it was a little more progressive shall we say. It seems to wait and then it's a little too fierce with the braking, unnecessarily so.
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391
we need Bobby for that answer!
| Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Yes the brake lights come on if it applies brakes in addition to backing off the throttle.
| eddiek62 Member Since: 02 Feb 2011 Location: Glasgow Posts: 139
The more I get used to ACC the more I like it. Easy to touch the accelerator when required and makes the commute much more relaxing. |
| kp Member Since: 18 Jan 2012 Location: Ex Bashing! Posts: 91 |
I had a RRS TDV8 HSE recently with ACC fitted and it was very nice indeed, just wish it was a little softer in its approach to things should we say |
| jdwoodbury Member Since: 29 Sep 2011 Location: Swindon Posts: 19 |
I must admit I can't stand it, I override it in heavy traffic as I don't like the way ACC cuts in. |
| andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155
I sometimes find it hard enough staying awake on a long journey.... without letting the car do some of the driving...
| All times are GMT |
