| RRSPORT.CO.UK | ||
|  | Home > General > flat battery? |
| baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273      | upper tailgate switch was the cause of my battery drain remove the rubber cover off the switch and see if the contact bar is corroded if so new switch on charge your battery this could be the cause | ||
|  Thu Jan 19 2012 4:19pm |
| eddiek62 Member Since: 02 Feb 2011 Location: Glasgow Posts: 139      | Just replaced mine. Battery drain co-incided with the upper tailgate stopping working. New switch has it working fine again but not left it long enough to know if battery drain is cured. Get the new switch off ebay and it's only about a 5 minute job to change switch yourself. | ||
|  Fri Jan 20 2012 8:54pm |
| richyrich70 Member Since: 04 Nov 2011 Location: Cheltenham Posts: 28    | on the case... Out of interest have a Varta battery fitted at present, local battery dealer suggests an Exide for better performance. Will check that after tailgate switch replacement. | ||
|  Fri Jan 20 2012 11:37pm |
| Posting Rules
