![]() | Home > Maintenance & Modifications > Paddle shift upgrade on my2010 |
| JUCOTT01 Member Since: 12 Aug 2010 Location: GLASGOW Posts: 89
I did this on mine you might well need a new clock spring |
But just for paddle shift you will only require the paddles a loom for the steering wheel and a software upgrade to enable them
| swalker900 Member Since: 12 Sep 2010 Location: Bury Posts: 46
Thanks Julian. - yes got them |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Sorry, sort of related hijack, how easy is it to add the heated wheel to a car without and what is needed? ON THE WAY: BMW F21 M140i
To add a heated wheel you will need the heated wheel itself, you will also need to check the "Clock spring /Rotary coupler"
Thanks JUCOTT01, so how is it activated, do I need a button, or is it activated with the rear/front screens or the seats ? ON THE WAY: BMW F21 M140i
When you aquire your new wheel with the heated element in it it will have a button on the opposite side to the ACC it is part of the new wheel |
^^^ Thanks mate |
Give Pete at Bell Autos a shout he might well have a wheel in stock |
| Stuart's the man Member Since: 02 Jan 2012 Location: Glasgow Posts: 35 |
plug and play once you get bits, think you need to run a power wire up to switch, this has been well covered on d3 site |
| mgadel Member Since: 08 Nov 2015 Location: Adelaide Posts: 3
Is the steering wheel air bag the same in the RRS and the D4 ?
| jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83
Fitting just the paddle shifters requires nothing more than plugging them in on the right switch pack then enabling them in the CCF. If adding heated steering wheel, thats when you need the new clock spring.
| raheelc Member Since: 28 Dec 2015 Location: Virginia Posts: 5
I am planning on adding the paddle shifters to my 2010 RRS too. My vehicle already has a heated steering wheel, so do I only need the paddle shifters and new rear cowl? Where can I buy the appropriate cowl from (been looking online but haven't been able to determine whether it's the appropriate one or not)?
| All times are GMT |
